My engine shot a rod help
Old Jul 6, 2023 | 04:37 PM
taint's Avatar
taint
Originally Posted by Xtian Ruiz
not enough money my budgets round 700$😭
Not trying to be a peckerhead, but you could plug and play something like this, then take your time on building the engine you want.
[url=http://​​​​​​​[ame]https://www.facebook.com/marketplace/item/286353343892494/?ref=search&referral_code=null&referral_ story_type=post&tracking=browse_serp%3Aa 3961d68-4d34-4835-800c-538164292ccb]​​​​​​​[/ame]
Old Jul 6, 2023 | 04:57 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Originally Posted by 427Hotrod
Rod length doesn't change the stroke or cubes. A 355 is typically a 350 bored .030". The rod just hooks the crank to the piston.
JIM
tell it to the "355" group.
Old Jul 6, 2023 | 05:12 PM
1972bluelt1's Avatar
1972bluelt1
So you're saying, put 6" rods in a 350 and it's a 355?
Old Jul 6, 2023 | 05:14 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I say what I mean.
Old Jul 6, 2023 | 05:36 PM
Xtian Ruiz's Avatar
Xtian Ruiz
Here an update
Completely unfixable 2 holes in the block shame shame well if anyone wants to buy a greenwood kitted 79 be my guest needs and engine lol
Old Jul 6, 2023 | 05:40 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Here an update
sorry to hear.
find next gen 350 vortec truck or a orig style block.
can't say whats cheaper, depends on whats around you.
Old Jul 7, 2023 | 01:39 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I say what I mean.
Please explain it to us....who's the "355" group?
JIM
Old Jul 7, 2023 | 01:41 AM
427Hotrod's Avatar
427Hotrod
Those TBI 350's like in that pickup above are great ones for something like this. They go 200K miles regularly. The EFI keeps ring wear to near nothing. Find a decent one and swap in. Heck...they even have the good Vortec heads if you get the right one.
JIM
Old Jul 7, 2023 | 05:36 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I believe he means 355 cu inch engines. Which would be a .030 over stock bore. Some folks think changing rod length changes cubi inches. It involves changing the piston too which results in a net zero change. Stroking an engine involves changing the crankshaft to a longer stroke which is a totally different thing and gaines cubic inches of air volume
Hence a 350 with a 400 crank gives you a 383....
Some folks heve the machine shop change the rod which requires a new piston which most will over bore and then tell the owner they have a 355 now and the mistakenly believe the rod changed the cui
Old Jul 7, 2023 | 07:02 AM
Mr D.'s Avatar
Mr D.
Here an update
Ok, now that we know that lets move on. You live in TN, land of Rednecks and junkyard Chevy engines. What is your budget to get the car back running? Or the real question is, is this your car or one you were looking at?
Old Jul 7, 2023 | 08:38 AM
1972bluelt1
Probably a moot point for this thread, but making a 383 also required a considerable amount of clearancing.
Old Jul 7, 2023 | 08:54 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
This was true a few years ago...but the last three I built required zero clearancing....Scat and Eagle both re-profiled their rods to clear the cam lobes and pan rails.....
I wouldn't build a 383 for a long time because nobody would pay for the clearancing.....then I was told that the rods were fixed and mocked up a One Piece main seal block with all 8 pistons and no rings with a Hydraulic Roller cam that had a standard base circle and everything cleared by a mile....
Jebby
Old Jul 7, 2023 | 09:04 AM
  #33
1972bluelt1
Jebby
Good to know. It's probably been 20 years since I built a 383.
Old Jul 7, 2023 | 09:07 AM
  #34
calwldlife's Avatar
calwldlife
St. Jude Donor '22
JIM
5.7in is stock 350
6.0in is known as 355
L48 has dished pistons, don't look for those.
Look for L82 pistons. early or late up to 80.
this is IF block is ok
no where did I state any cubic inch
Old Jul 7, 2023 | 10:58 AM
  #35
427Hotrod's Avatar
427Hotrod
So what does 355 mean in your context??? You referenced a stock 350...so the conclusion (obviously wrong on my part) is that 355 was referring to cubes.
So once again...explain 355 to us in your context. Willing to learn how the "355 folks" think and look at things.
JIM
Old Jul 7, 2023 | 11:17 AM
  #36
calwldlife's Avatar
calwldlife
St. Jude Donor '22
JIM
goodness.
use 6 in rod and it is known as 355.
what is hard about that.
like I said ask 6 in rod guys.
sounds like some here use bored over cubic inches when someone asked what engine you have.
nuts
Old Jul 7, 2023 | 11:38 AM
  #37
drwet's Avatar
drwet
goodness.
nuts
It's not hard, but it is incorrect. Please provide a reference to someone else who is calling a 350 with 6" rods a "355". I think we are all very curious how this misconception got started.
To My engine shot a rod help
Old Jul 7, 2023 | 11:39 AM
  #38
Xtian Ruiz's Avatar
Xtian Ruiz
this is my car and budgets like 700$
Old Jul 7, 2023 | 11:42 AM
  #39
calwldlife's Avatar
calwldlife
St. Jude Donor '22
its a designation.
I didn't name it.
Been around since late 90s.
L-82 and L-48 are designations.
The only wrong thing is your thinking
Old Jul 7, 2023 | 12:04 PM
  #40
CSIROCZ's Avatar
CSIROCZ
its a designation.
I didn't name it.
No, it isn't a designation. You've gotten yourself confused or been misled by someone else who is confused. L-82 and L-48 are codes used by the factory to designate which engine option was selected. "350" is not a designation - its the number of cubic inches the engine has. "355" is a bored over 350. It has 355 cubic inches of displacement. It has nothing whatsoever to do with rod length. Rod length doesn't change engine displacement. Putting new rods in doesn't suddenly make it a 355. Putting new pistons in with a .030 overbore does. Since you cannot change to a 6" rod without new pistons (due to the compression height of the piston), and since new pistons are generally installed with an overbore, you end up with a 355 by way of the overbore - not the rods. Putting in 5.7" rods would still result in a 355 by way of an overbore. Putting 6" rods in a stock bore would still result in a 350, despite the extra rod length.
