Tachometer problem
Old Jul 6, 2023 | 06:30 AM
micmak's Avatar
micmak
Default Tachometer problem
This question has probably been asked many times, but when I ran a search, I couldn’t find it.
So, here is my problem:
I have a 1982 C3 CE. The tachometer isn’t behaving. When I start the car, it flickers and the needle jumps around for a second or two. Then it settles at the top end, and stays there regardless of engine RPMs. Where should I start to fix this? Is it a bad ground, or something?
Old Jul 6, 2023 | 06:34 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I am indeed surprised you can't find this. Comes up on here all the time.
Simple answer , new tach board.
Old Jul 7, 2023 | 01:17 AM
micmak's Avatar
micmak
Really? Is there no typical "check this", or "ensure that", before you start replacing items?
Old Jul 7, 2023 | 04:27 AM
hunt4cleanair's Avatar
hunt4cleanair
95 percent of the time...it's the tach board.
Read about it here
http://www.hunt4cleanair.net/Articles/tachboards.pdf
Old Jul 7, 2023 | 05:01 AM
4-vettes's Avatar
4-vettes
yes, a lot of people on here have stated over and over again. Unplug your tach filter and see if that makes a difference. The fact that your tach is reacting, although incorrectly. Shows the signal wire, power and ground are hooked up.
Sorry, it's that simple.
3 wires to a electric tach. Power, ground and signal. If your distributor was at fault your car wouldn't run.
It's your Bloody tach board. It's happened to all of us.
Old Jul 7, 2023 | 02:45 PM
Eric P's Avatar
Eric P
who's the best place to purchase a tach board from ?
Old Jul 7, 2023 | 07:42 PM
interpon's Avatar
interpon
post 140
also op..rev past 3500 and the tach will probably return
https://www.corvetteforum.com/forums...uestion-7.html
To Tachometer problem
