Weld chrome bumper?
Old Jul 17, 2023 | 07:37 PM
wwiiavfan's Avatar
wwiiavfan
Default Weld chrome bumper?
Looking ahead to my ‘71 resto, I’d like to fix that annoying bulge at the center of my front bumper by slicing a thin pie shape from it and bumping it flat and welding it closed.
Question is, can that bumper material be welded?
Popular Reply
Jul 18, 2023, 11:55 PM
lars's Avatar
lars
Originally Posted by Kidster71
With the byproducts of the chrome process killing the planet, it’s good to see it going away.Richard
Good grief.
Old Jul 18, 2023 | 12:28 AM
lars's Avatar
lars
Yes, it can be welded. No problem. It's plain mild steel. After welding, it will require a significant amount of metalworking to prepare it for re-chroming. You will have a lot more time and money wrapped up in it than the cost of a new re-pop bumper (only $500). You're not reworking and re-chroming that bumper for less than that. Do you know how many places there are left in the U.S. that still do quality chrome work..? Thank your liberal-*** green government. If cost is no object and all you want is a nice, perfectly-formed bumper without the normal "bulge" in the middle, slice it, weld it, and do the metalwork. Send it out for chroming. It will look fantastic. With your labor and the chrome work, I'll bet you'll have over $2K in it. But it will look very nice.
Lars
Old Jul 18, 2023 | 05:52 AM
wwiiavfan's Avatar
wwiiavfan
Yes there is a good chroming vendor about a half hour away. I plan on consulting with them before starting. I will not be doing traditional chrome on this.
Old Jul 18, 2023 | 06:57 AM
lionelhutz's Avatar
lionelhutz
DO NOT WELD ON THE CHROME. It will attempt to kill You, and might succeed. Make sure its fully stripped to bare metal where you weld.
Old Jul 18, 2023 | 11:33 AM
lars's Avatar
lars
Anyone capable and qualified to do a proper weld joint knows that the weld joint must be properly prepped, which includes the removal of all plating and coatings in the weld area and heat affected zone. That's normal, required welding practice for any welded joint. Additionally, a qualified welder also knows to avoid and mitigate inhalation of the fumes coming off the parent material and filler materials when welding certain material types and using certain alloy fillers, as they often contain hexavalent chromium, regardless of the plating on the parent material.
Welding is a special process than can be hazardous. Bottom line is the same as with anything else: If you're not qualified to do it, don't do it...
Lars
Former AWS & ASME Welding Certifier
Old Jul 18, 2023 | 12:57 PM
wwiiavfan's Avatar
wwiiavfan
No worries guys, I’ve been a Mechanical Engineer for 32 years, a lot of it in metal fabrication. I know my way around a welder. I just wasn’t sure what the bumper material was. It almost has a cast look to it, but I didn’t think factories were using thin castings back then.
Old Jul 18, 2023 | 01:42 PM
lars's Avatar
lars
No, it's just plain stamped mild steel. If you're a mechanical engineer, it's P1 Group 1 for welding. For GTAW (DC Straight), use E70 filler (SFA 5.18) with Argon shielding. If you put a little pre-heat into it it will flow real nice.
The stamping process is why the bumper has that annoying bulge right at the tip of the "V", because the stamped steel has noplace to go when formed at that angle.
Lars
Old Jul 18, 2023 | 03:37 PM
Kidster71's Avatar
Kidster71
Highway Man
I’m contemplating doing the same thing.
The factory bumper fits so much nicer than the repops that I’ve seen with the end tips bent out.
I’ve spun a nut on the one mount so while welding that I was going to cut and flatten the centre.
I was actually thinking of a chrome alternative like chrome paint. With the byproducts of the chrome process killing the planet, it’s good to see it going away.
Cheers,
Richard
Old Jul 18, 2023 | 11:55 PM
lars's Avatar
lars
Good grief.
Old Jul 19, 2023 | 01:36 PM
Sayfoo's Avatar
Sayfoo
I did this 20yrs+ ago when chrome shops were numerous and cheap. But, when they "streightened" it, the bump came back. Many, many c3's have this. Factory original????
I wouldn't do it again, too many other things to fix on my car.
Old Jul 19, 2023 | 03:52 PM
Tranz Zam's Avatar
Tranz Zam
Originally Posted by lars
Good grief.
Not something I thought I'd ever read on an automotive forum lol
Old Jul 21, 2023 | 06:45 AM
mrvette's Avatar
mrvette
When I bought my '72, it had a repro bumper on it, and after someone backed into it, the replacement was the same, damnit....the main part fits fine, about 1/2 inch from the plastic all across the front, BUT the ends are over an inch.....near 1.5 inches from the body....both sides, so the question is WHY?? can't the repro guys stamp the thing correctly??
Old Jul 21, 2023 | 11:40 AM
lionelhutz's Avatar
lionelhutz
Sure, and welding on chrome can easily be deadly. Not sure why you'd post comments trying to imply my warning is stupid and unnecessary...
Old Jul 21, 2023 | 01:06 PM
Shovels and Vettes's Avatar
Shovels and Vettes
It’s supposed to have that bump
Old Jul 21, 2023 | 01:31 PM
wwiiavfan's Avatar
wwiiavfan
My original is the opposite. Tight on the ends, but farther away than it should be in the center. I’m thinking it may have been pulled on in the center at some point and slightly tweaked.
Old Jul 21, 2023 | 01:32 PM
wwiiavfan's Avatar
wwiiavfan
Yes, but we don’t have to like it. Same reason many guys go thru the labor to straighten up door and body gaps. May have been crap from the factory but it doesn’t have to stay that way…
Old Jul 22, 2023 | 09:43 AM
Tranz Zam's Avatar
Tranz Zam
How dare you customize your own car? lol
To Weld chrome bumper?
