Carb setting help
Old Aug 28, 2023 | 09:05 PM
keno3434's Avatar
keno3434
2nd Gear
Default Carb setting help
Just had my 454 rebuilt and the mechanic put a used Holley 650 double on it but didn’t set it up properly… he re-jetted it saying it’s running to lean and now I see nothing but black smoke when idling. I put a vacuum gauge on it and my highest vacuum is when I close the front two mix screws completely closed…
can I assume that the jets he installed are just to large or do I have something else going on…
please help
Old Aug 28, 2023 | 09:28 PM
Arg0413's Avatar
Arg0413
Your idle isn't affected by your jetting. It's determined by your transfer slot and idle mixture screws - which you should have 4 corner idle on a DP. Is this a new carb? Have you read Lars' paper on Holley set up?
Old Aug 28, 2023 | 09:51 PM
lars's Avatar
lars
Jetting has no effect on idle rich/lean condition. In fact, you can take the jets completely out of the carb and the idle will remain unchanged, as long as the carb is idling on the idle circuit. You have something else going on - carb needs a complete baseline setup... Sounds like your hack "mechanic" is a real gem.
Lars
Old Aug 28, 2023 | 11:23 PM
keno3434's Avatar
keno3434
2nd Gear
yes 4 idle screws, one in each corner.
no it’s a used carb.
no I have not read Lars.
I was on holleys web site and watched a bunch of set up videos… it said if you have black smoke to down size 2 jet sizes… it didn’t talk about why when I bottom out the mix set screws I get the highest vacuum… normally the highest vacuum should be somewhere around 1-1/2 turns out not turned all the way in.
Old Aug 29, 2023 | 12:03 AM
lars's Avatar
lars
Few Holleys will run at 1-1/2 turns. Most are at 5/8 to 7/8.
If the engine is running with the mixture screws all the way in, the carb is supplying fuel to the engine through some source other than the idle circuit. Most likely from fuel dribbling out of the main discharge nozzles. You need to tear that carb down and do a correct setup on it.
Old Aug 29, 2023 | 09:10 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What intake manifold are you running?
We like pics here.....
Jebby
Old Aug 29, 2023 | 09:58 AM
HeadsU.P.'s Avatar
HeadsU.P.
A nice feature about those 650 DPs is the float setting inspection hole (sight-plug) on the fuel bowls.
Have you glanced at the float level while idling?
Old Aug 29, 2023 | 10:13 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Main source of fuel dribbling is the metering block gasket not sealing.......always use a new gasket when doing a new jet change......you can reuse it a few times but once it heat cycles it will stick to the main body slightly.....and form itself to the metering block, or if it sat and got dry and you removed the metering block....they usually leak. You said the jets had been changed.....and I bet your "mechanic" just reused the old shitty gasket.
It is easy to see while running....shine a pen light down the primary venturi and see if it is dribbling gas out of the boosters.....if it is, you are taking it apart.
Jebby
To Carb setting help
