engine stall C3 350 1981
Old Sep 2, 2023 | 07:43 AM
Razorr's Avatar
Razorr
Cruising
Default engine stall C3 350 1981
Warm weather stall
The starts fine and will run for 2 miles no issues, stop at a light and I can feel in running rough, 1/2 mile down the road it just shuts off. I drove another couple of miles and it stalled out 3 more times.. turned around to take it home and it didn't stall again for the 4 miles back, ran great. When it stalled the last time I took the air cleaner cover off check for gas, it was getting gas. only 600 miles on rebuild engine and carb.
Old Sep 2, 2023 | 08:52 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
are you stock with computer?
Old Sep 2, 2023 | 11:23 AM
Razorr's Avatar
Razorr
Cruising
Yes it is the stock computer
Old Sep 2, 2023 | 12:09 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
so for 595 miles ok?
hmm.
could be ignition control module.
Old Sep 2, 2023 | 12:31 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
choke ok right
Old Sep 3, 2023 | 06:57 AM
Razorr's Avatar
Razorr
Cruising
it appears to be working ok.
Old Sep 3, 2023 | 09:10 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Ok, fuel doesn't seem to be issue.
Electrical then.
Power to distributor
Dist components
ICM
Coil
mag pickup
Old Sep 5, 2023 | 12:04 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If it stalls when it warms up into closed loop then you have a sensor issue or Idle Mixture Solenoid issue.......
Jump the connector (ALDL) and see if there are codes......Google up old GM codes to learn how to read the codes and jump the connector.
Jebby
To engine stall C3 350 1981
