A arm bottom
Replacement ball joints should come with the bolts that replace the rivets.
anks
I also watched a YouTube video where they burnt the rubbers out and worked them that way, but I chose the air chisel.
throwing money at it???
Nahhh.
If the arms are in good shape no need to replace them, just rebuild.
Now at 63, it becomes a matter of time / money management.
I could do it myself but am I saving money?
Well, here is just a quick time / cost analysis..
First, put a value on your time...
I make $75 per hour on my regular job.
Lets say it takes 4 man hours to break down 4 A arms. (Sounds simple, but time yourself and rate your frustration factor)
My labor would be worth $300.00
Then I have to have them blasted and powder coated. $50
Then I have to buy the ball joints and bushings for uppers and lowers... $200 for the front end rebuild kit with shipping...
Then add the time to install the ball joints and bushings... Another 4 man hours...$300.00
So I could do it myself and spend $850 worth of time / money and have the frustration / satisfaction...
OR
Spend $600 for a professional job, with warranty. ZERO frustration, but no less satisfying...
Also, the 8 hours of time NOT spent rebuilding the A arms, is time I can spend doing something else.
If you do this analysis for all aspects of the restoration, you will find this is the difference between a 3 year project and a 1 year project...
But...I am all for learning...Sometimes that learning costs "tuition"....That tuition is time and money.
At 63, time is more precious than money. Less time spent in the garage is more time enjoying the drive...Spend wisely...
