For a 1980, my wipers only have one speed and hear the clicking relay in the back. I know this is the fix but is the washer pump controlled through this? It's not operating ...https://www.lectriclimited.com/inter...r-module-86267
Well, yes it goes through the module so the when the washer motor starts the wipers start also and have a timed run, when the washger stops pumping the wipers will swipe a few times to get rid of the excess...
Couple things, take the controller out and check for cold or bad solder joints. I went through this with mine, they stopped working right after I used the 12V feed for the wiper motor for my Holley (by god) electric choke.. So I assumed I shorted something out and I went through a bunch of testing and a module. So over a drink a friend said, got any contact cleaner...BINGO...sprayed the switch out and all is well... Give it a try, those modules have gone way up...
60
I vaguely remember this thing going bad on my other 80 many years ago. Everything is going way up along with the price of these cars. This car I just bought has a list of small little issues I'm fixing but I feel I got a fantastic deal.
Got this thing apart, don't see any obvious burns or broken solder joints. What usually fails on these ? Is there a way to get 2 speeds and the washer pump operational ?
