Gauge power issue ...
Now, when I plug in the harness to the cluster, this is when the issues start, I first came aware of the issue when my newly installed volt meter had no reading when the key is switched to the on position. So when I read the power with my multi meter (the power for the volt meter is taken from the switched temp 12v supply) the reading is only 2.1v, it is the same at the positive side of my fuel gauge. If I unplug the temp and fuel gauge the 12v signal returns, plug either in ... 2.1v? Now I am just confused, and add insult to injury, if I take the pod and plug a 12v input in from my test bench power supply, my volt meter reads 12v and fuel and temp energize ready for their sensor input.
Now I did convert my 71's amp meter to a 72 volt meter but again, all seems well with this mod, so throw them idea's out there if you could cause at this point I'm ready to do it bodily harm!!
Dave
https://www.corvetteforum.com/forums...s-back-31.html
Dave
