Q-Jet Accelerator Pump Questions
Old Dec 2, 2023 | 11:59 AM
OrangeC3ButImAnAggie's Avatar
Default Q-Jet Accelerator Pump Questions
Hello y'all, I have a couple questions regarding my 1974 L-82 Quadrajet's accelerator pump. I'm becoming more convinced that something may be wrong with it.
  1. What exactly does the accelerator pump do? When does it activate? Does it send a stream of gas at all time when car is running? Or only when pedal is depressed?
  2. I have read that when twisting the throttle, I should see a "steady stream" of gas flow out. Should this happen when cold or running? For me, when car is cold nothing shoots out, when running it sprays out, when warm it dribbles out. This doesn't seem right.
  3. With a bad accelerator pump, I assume that means the little rubber cup has broken. If this is the case, would fuel evaporate out of the bowl? Perhaps this is my gas smell. Perhaps this is why on a cold start it has to crank for 4ish seconds to pump fuel into the carb.
  4. The install of the accelerator pump doesn't look to difficult. I can't find a new one from any major vendor, nor the upper carb/airhorn gasket. Any suggestions? Ebay new-old-stock delco parts?
I would really appreciate any help!
Old Dec 2, 2023 | 12:34 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
#2: The steady stream is seen with the engine off, hot or cold. When the engine is running you may see a small bit of it but the rush of air going past aerosol-izes it pretty quickly, so you lose that strong liquid stream.
Old Dec 2, 2023 | 02:24 PM
MelWff's Avatar
MelWff
  1. What exactly does the accelerator pump do? When does it activate? Does it send a stream of gas at all time when car is running? Or only when pedal is depressed? Only when pedal is depressed
  2. I have read that when twisting the throttle, I should see a "steady stream" of gas flow out. Should this happen when cold or running? For me, when car is cold nothing shoots out, when running it sprays out, when warm it dribbles out. This doesn't seem right. Cold, hot, off, on when you open throttle. No movement no spray.
  3. With a bad accelerator pump, I assume that means the little rubber cup has broken. If this is the case, would fuel evaporate out of the bowl? Perhaps this is my gas smell. Perhaps this is why on a cold start it has to crank for 4ish seconds to pump fuel into the carb. Should not have smell from bad pump piston
  1. The install of the accelerator pump doesn't look to difficult. I can't find a new one from any major vendor, nor the upper carb/airhorn gasket. Any suggestions? Ebay new-old-stock delco parts?
Google Quadrajet parts not vendors.
Old Dec 2, 2023 | 03:53 PM
REELAV8R's Avatar
REELAV8R
Cliff's has the part you need. Don't get just any accel pump diaphragm. Cliff's are ethanol resistant.
https://cliffshighperformance.com/
Old Dec 2, 2023 | 05:16 PM
barkingrats
I've ordered gasket sets from Mike's with good results: https://www.carburetor-parts.com/
If I had known that Cliff Ruggles sells parts I would have definitely ordered from him -- which I'll do from now on.
Old Dec 2, 2023 | 07:51 PM
lars's Avatar
lars
Cliff has stopped building carbs and is now only selling parts - that's what he does. No more carb rebuilds - parts sales only.
Lars
Old Dec 4, 2023 | 09:29 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Your Accelerator pump adds an extra shot of fuel to give the engine a head start to rev before it can draw fuel through the boosters........it operates everytime and only when you hit the throttle......
I keep at least two Cliff's Q-Jet pumps in my box.......
I get at least that many customers with dead pumps every year.......
Jebby
Old Dec 4, 2023 | 10:12 AM
Thanks for all of y'alls responses! I'll go ahead and pick me up Cliff's accelerator pump and airhorn gasket.
Old Dec 4, 2023 | 10:22 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Look here at the threads Lars has posted doing customer carbs.......awesome photos and explanation......and the proper way to remove the pump arm up top to make the job 10 times easier......you tap the pin in with a very small drift or bit.....take the pump arm right off.
Jebby
Old Dec 4, 2023 | 07:39 PM
lars's Avatar
lars
I think one of the posts that Jebby is referring to may be this one. It has some photos and narrative that may assist you.
https://www.corvetteforum.com/forums...980-q-jet.html
Lars
Old Dec 4, 2023 | 08:03 PM
Thanks Lars! That's one of the most clear and thorough set of instructions I've ever read. Looking forward to my first dive into my carb...
Old Dec 15, 2023 | 04:03 PM
Follow up: Ordered a new accelerator pump, airhorn gasket, and fuel filter from Cliff. Installed the parts using Lars' excellent instructions. The old pump was literally in pieces in there. Now I see how the fuel stream from the pump y'all are talking about is really supposed to look like! Before it just sort of dribbled out. Thanks everyone.
Old Dec 15, 2023 | 06:49 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
this place rocks
Old Dec 15, 2023 | 07:36 PM
ZIOGEO's Avatar
ZIOGEO
Lars Grimsrud has a good white paper on the Q-Jet. He recommends NAPA part number 2-4055. This is an ethanol-resistant pump that works very well. I used it to replace the pump in my carb.
The paper itself is a little wordy but its complete and worth reading if you plan on keeping the Q-Jet.
Send him an email requesting his Q-Jet papers and he'll reply with them attached v8fastcars@msn.com
To Q-Jet Accelerator Pump Questions
