C3 steering valve, ram, pump rebuild
Old Jan 15, 2024 | 09:46 AM
grumman41's Avatar
grumman41
Default C3 steering valve, ram, pump rebuild
I’ve been really pleased with the work I had done by Blair but found out they only rebuild the steering valve and not the ram and pump. My goal is to rebuild and use my components as they came on the car. Any recommendations for high quality rebuilds on all three components?
Thanks gents!
Old Jan 15, 2024 | 10:00 AM
interpon's Avatar
interpon
I think the ram rod needs to be smooth and still have chrome otherwise it may leak scratch seal.
i think rock auto sold gates kit
Old Jan 15, 2024 | 08:11 PM
grumman41's Avatar
grumman41
Any recommendations on power steering pump rebuilds?
Old Jan 15, 2024 | 10:17 PM
interpon's Avatar
interpon
post 3 and 5, 15 etc
https://www.corvetteforum.com/forums...leak-79-a.html
Old Jan 16, 2024 | 08:11 AM
grumman41's Avatar
grumman41
Great write up, I’m just in a time crunch and looking for a rebuilder.
Thanks.
Old Jan 16, 2024 | 10:03 AM
augiedoggy's Avatar
augiedoggy
I can tell you its not a hard job. I tackled rebuilding all three when I bought my car like 14 years ago. I had no experience doing so.
Old Jan 18, 2024 | 09:40 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The rod is easy but one thing you need to be aware of........most original high mileage steering rams leak when the steering is at center because the shaft actual wears in the center position from the millions of movements it gets just going straight down the road......
Visually inspect the ram at this position.....if there is any visual wear at all....toss it, it will always leak no matter what you do.
Jebby
To C3 steering valve, ram, pump rebuild
