HP gain
Old Feb 19, 2024 | 11:24 AM
Lotventures's Avatar
Lotventures
Default HP gain
Hello all,
I have an 81 with the L48 or L81 whichever you prefer to call it. I am wondering what kind of HP gain can i get just by getting rid of the emissions and adding long tube headers and side pipes ?
Thanks for any input
Old Feb 19, 2024 | 11:34 AM
MelWff's Avatar
MelWff
Originally Posted by Lotventures
Hello all,
Stock 1981 uses a computer controlled carburetor and distributor and lockup torque converter. You cannt remove anything without also replacing the carburetor and distributor.
Old Feb 19, 2024 | 11:37 AM
Lotventures
Thank you for that bit of information
Old Feb 19, 2024 | 12:52 PM
Lotventures
One more question if you don't mind.
If I replace the carb and distributor, something also needs to be done with the lockup converter correct?
can I do something about that without changing the tranny
Old Feb 19, 2024 | 12:56 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You can run long tube headers as long as you put a bung in for the O2 sensor.....all of the AIR pump equipment can come off too......I do not believe it will trip the computer.....
But most will just get rid of the system as it is in the toilet for support....and not really tunable.....
4 barrel L-48 (L-81) 350 will turn about 275hp to the crank or about 220-230hp to the tire with headers, correct timing and tune, and a good Q-Jet. Doesn't sound like much but consider bone stock it throws a massive 150-160 to the tire.....
You will need a camshaft at that point to make anymore power.
As far as the TH350C, just run it unlocked......it will not hurt it....but if you want it there are places you can get the lockup switch at......
Jebby
Old Feb 19, 2024 | 01:09 PM
Lotventures
Just run it unlocked......it will not hurt it....but if you want it there are places you can get the lockup switch at......
Jebby
Thank a bunch Jebby.
Should I just put a new non computer controlled Rochester on it with the original intake ? Same for the distributor or can you suggest something better
Thanks again, you guys are great
Old Feb 19, 2024 | 01:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
basically, remove belt from air pump
unhook vac line to egr
run long tube headers with proper position o2 sensor, dual exhaust no cat.
leave all wires plugged in to smog stuff.
you may get 25-30hp.
it will run fine.
sorry,
Old Feb 19, 2024 | 02:20 PM
Lotventures
it will run fine.
sorry,
Thank you
Old Feb 19, 2024 | 03:17 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Thank you
up your base timing from 6deg to hell, 14ish
after headers install using dwell meter, set on 6cyl, adjust your carb air bleed to
30-35 deg
Old Feb 19, 2024 | 03:20 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
any real power gains will require heads cam.
depending on cam, you may need a non computer carb and distributor
Old Feb 19, 2024 | 03:24 PM
Lotventures
Ok, thank you, the headers and side pipes are really just for looks but was just curious about the HP
Thanks again
Old Feb 19, 2024 | 04:40 PM
Richard Daugird's Avatar
Richard Daugird
Free flowing exhaust never hurts, only helps.
Old Feb 19, 2024 | 05:43 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Thanks again
just saw the visitor message you left.
I covered everything here,
If you haven't read it or don't understand post here only.
thanks
Old Feb 19, 2024 | 06:38 PM
7T1vette's Avatar
7T1vette
First efforts are:
1) make absolutely sure the carb secondaries are FULLY opening when you depress the accel pedal in the car! Exercising the throttle with your hand is NOT the same thing. Secondary plates should be 90* vertical when throttle hits the stop.
2) also make sure the secondary lockout tab is not PREVENTING secondaries from opening at all...
3) if you still have the 1-year-only ECU system operational, disregard this step. Otherwise it will provide the biggest "bang for the buck" for performance--- Recurve the distributor for performance. GM set it up for "lowest warranty"...not for performance
With vacuum advance disconnected and blocked (to prevent vacuum leak), set MAX centrifugal advance at 34* when RPM between 2500-2800. From factory this rpm range can be 3500+. Make weight springs lighter to lower RPM @ MAX advance. You can mix springs for fine tuning, if you want.
4) AFTER you have done all the above stuff, you can add performance with cam, heads, & headers. Those 3 need to be selected properly for the engine to BREATHE properly for better performance.
P.S. Many folks who properly do Steps 1-3 find that the performance level they NEED is already available.
Old Feb 19, 2024 | 06:42 PM
Lotventures
Originally Posted by 7T1vette
First efforts are:
Thanks very much for the help. I don't want to go into the motor, until it is dead, lol.
Old Feb 20, 2024 | 08:21 AM
Dogmark's Avatar
Dogmark
Compare the size of your exhaust under the car to the side pipes I believe the side pipes are smaller in diameter costing you horsepower even though they look better (lol), headers alone should give you 20 hp!
Old Feb 20, 2024 | 08:24 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You have to run a non-computer distributor......unplugging the carb crosses up the ECM.......and the ECM doesn't have **** for a curve in it anyway......
The GM Crate HEI or a Davis DUI is a great option......stay away from cheap China unless you have a Sun machine to curve it.......
Even a stock used HEI isn't bad....they usually pull 21 degrees timing so you set it at 15 at idle and it will have 36 total......
Jebby
To HP gain
Old Feb 20, 2024 | 09:38 AM
MelWff's Avatar
MelWff
The individual tubes are 1 7/8" going to a 4" collector. Not smaller.
Old Feb 20, 2024 | 01:21 PM
Dogmark's Avatar
Dogmark
Not the headers, The rest of the exhaust system under the car compared to the side pipes!
Old Feb 20, 2024 | 01:46 PM
MelWff's Avatar
MelWff
the rest of the system would be 2.25" or 2.5" for 4 cylinders per side.
