69 sb Fuel Pump difference?
Old Mar 23, 2024 | 12:12 PM
mbp's Avatar
mbp
Default 69 sb Fuel Pump difference?
Hello. I have a couple a question about a fuel pump for my 69, 350 with a Rochester. The first is what is the difference between the Carter M 6120 and Delphi MF0158. Both listed on the RA website and probably the ones sold by the vendors. They are listed for a 350 but the Delphi is for a Holley. The pressures and flows appear to be the same and I didn't even know the 350 ever had a Holley in 1969. So my question is if the Delphi will work with a Rochester, could someone explain the difference? Thanks in advance.
Old Mar 23, 2024 | 01:00 PM
J.Abbott's Avatar
J.Abbott
The fuel pump for the Holley does not have a return in it. If you look on your frame, the Holley equipped Vettes only have a single fuel line where as the Rochester has two, one for fuel feed and one for fuel return.
Old Mar 23, 2024 | 07:06 PM
mbp's Avatar
mbp
Thanks J.Abbott. My return comes off the fuel filter so I guess either pump will work.
Old Mar 24, 2024 | 12:52 PM
J.Abbott's Avatar
J.Abbott
Yes you could use the single outlet, I forgot about that one, it was also used on the 68/69 sbc setup because the return was in the filter.
To 69 sb Fuel Pump difference?
