Starter Wiring on 71’ Vette
Does anyone have pics/info on how the starter is wired? fresh batt but no lights on dash, 12v at the starter tho
- i have a purple wire that is spliced to a orange wire that goes to solenoid back into the dash
- a black wire that goes into wiring harness that goes to a splice that has 1 going to goes under dash, 1 that goes to a connector in passenger fender well and 1 that goes to connector near wiper motor
-red wire that goes from horn relay? to a redneck looking fusible link to the solenoid
-yellow sheathed orange wire that goes to a connector with a red wire that goes to a connector with two wires w/green stripe to bottom of distributor
- ignition coil has 2 positive cables 1 that goes to a wiring harness to the horn relay? and 1 neg that goes to a kill switch under dash
im sorry if this is too much info i’m just so overwhelmed with all of this and i can’t find answers
the 4 wires i have that go to the solenoid
i guess the PO taped the red wire from horn relay to a fusible link to the solenoid ?
pic of fusible link?
orange to purple wire
yellow sheathed wire that goes to distributor
horn relay?
Pat
Pat
Pat
https://www.corvetteforum.com/forums...er-wiring.html
https://www.corvetteforum.com/forums...placement.html
also does it rewire the alternator wiring ? i have a brown wire on my alternator that’s cut
Pat
