Harmonic balancer
Old Apr 19, 2024 | 08:56 PM
Bailey78's Avatar
Bailey78
Default Harmonic balancer
Okay I have my engine together and the timing mark is way off. By three and a half inches. I bought one from Summit and besides being new it is the same. I have a 69 with the 350/350.
Do any of you folks have a idea where I can get the proper harmonic balancer ?
Old Apr 19, 2024 | 10:09 PM
MelWff's Avatar
MelWff
Have you considered it's not the balancer but the timing tab on the cover?
https://www.corvetteforum.com/forums/c3-tech-performance/4310328-timing-tab-indicator.html
Old Apr 19, 2024 | 10:13 PM
Bailey78's Avatar
Bailey78
Yes a friend of mine brought that up this evening.
I'm going to do a search and see what pops up. I may just do as I would have twenty years ago and make my own mark on it.
Old Apr 19, 2024 | 10:14 PM
MelWff's Avatar
MelWff
https://www.corvetteforum.com/forums...indicator.html
Old Apr 19, 2024 | 10:16 PM
Bailey78's Avatar
Bailey78
I've looked at other hormonic balancers and they all appear to be the same. Some a little different but the same mark in the same location.
Old Apr 19, 2024 | 10:17 PM
kossuth's Avatar
kossuth
There are some variations on timing marks out there whether the pointer is for a 12 o’clock pointer vs a 2 o’clock etc. Here is a link that might help.
https://www.daymotorsports.com/shop-...cer/PBD-1050-N
MelWff's Avatar
MelWff
New Cover with welded tab
https://www.zip-corvette.com/66-69-3...ain-cover.html
Old Apr 19, 2024 | 10:22 PM
mapman's Avatar
mapman
Photo of timing chain installed?
Old Apr 19, 2024 | 10:37 PM
Bailey78's Avatar
Bailey78
I didn't take a shot of that.
I had a good friend that's a Master Mechanic look at it. It all check out as installed and timed properly.
Old Apr 19, 2024 | 10:39 PM
Bailey78's Avatar
Bailey78
From the research I've done this evening I have come to the conclusion timing marks have moved over the years.
Old Apr 20, 2024 | 02:05 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Is this image showing the mark position with the engine at TDC #1?
Are you sure it's not set at TDC #2? (#1 is the forward driver's side piston while #2 is the forward passenger side piston.)
Old Apr 20, 2024 | 07:46 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
are you sure the harmonic balancer didnt slip? You can buy a nice new one from Summit or get that one rebuilt
Old Apr 20, 2024 | 07:57 AM
Tech141's Avatar
Tech141
Are both of your valves on #1 cylinder closed with the#1 piston at TDC? Is the dizzy rotor pointing at your #1 spark plug wire?
IMO - Harmonic balancer slippage does happen, but that would be a LOT of slip, and the spacing, being pretty exact at 45 degrees is suspect, as 67:72 points out.
Old Apr 20, 2024 | 08:27 AM
Bailey78's Avatar
Bailey78
I have it at TDC on one..
Very positive it is timed right.
Very positive I'm going to add my own mark to it.
I have spoken to a few different people about it.
I even had a master mechanic come take a look.
My work is right.
Old Apr 20, 2024 | 08:40 AM
HeadsU.P.'s Avatar
HeadsU.P.
I picture of the timing chain is not important here. In fact, you don't even have to have a chain installed.
What IS important is the relation of the key-way on the balancer and the TDC mark on the balancer in relation to the pistons position in the bore, TDC
The cranks keyway position, balancer mark is the issue, not where the camshaft is.
Old Apr 20, 2024 | 08:50 AM
Bailey78's Avatar
Bailey78
Key way is at 12:00 number one at TDC.
My timing marks are aligned next to each other.
I'm making my own mark on the hormonic balancer and running it.
Gotta get a good carburetor to bench test it and break it in. I will know then if I F'ed up something.
Old Apr 20, 2024 | 10:33 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Chevy used at least two timing mark locations over the years. And it moved by a couple inches. And there is no telling what parts or combination of parts you actually have on there now after 50 years. The timing tabs and balancers need to be a "matching" style set.
Or the balancer could have slipped on the rubber.
To Harmonic balancer
Old Apr 20, 2024 | 12:52 PM
Piersonpie's Avatar
Piersonpie
You could verify TDC of your engine with a piston stop and put a mark on 0 of the timing tab you have. Very easy to do with the engine out of the car. Doesn’t matter what version harmonic balancer or timing tab you have, it will definitely be correct.
Old Apr 20, 2024 | 03:23 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Keyway at 12:00 is not correct. You are not at #1 TDC.
Look at the pic I posted, your balancer (engine) needs to rotate to match it.
Your keyway should point near to the timing cover bolt indicated by the red line above.
Use a piston stop & confirm.
#1 on a SBC is driver's front.
Then use this guide to tell you where the mark on the balancer should be vs the keyway slot: That will tell you if the balancer is good.
SBC engines have three (3) different timing pointer locations:-
  1. Pre '69 engines, TDC mark is 2° to the left of the keyway centre line;
  2. '69 and later, TDC mark is 10° to the left of the keyway centre line; and
  3. 1984-'95 engines, TDC is at 12 o'clock position on the damper.
Old Apr 20, 2024 | 05:07 PM
HeadsU.P.'s Avatar
HeadsU.P.
That's a great diagram. Very helpful.
