posi tuned
Old May 2, 2024 | 09:34 PM
GTR1999's Avatar
GTR1999
Default posi tuned
Content removed
Old May 2, 2024 | 11:13 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
OK I'll play...
12 bolt spiders?
Old May 3, 2024 | 12:00 AM
GTR1999's Avatar
GTR1999
Yes indeed, 12 bolt - 30 spline, NOS Eaton Net Forged spiders, will be used with Tom's 1350 axles, hardened and cryo treated.
The new spiders and fiber clutches were removed. Solid steels with the 12 b spiders will be used.
Case milled, double bored, cross shaft holes bored for 10 x12 shaft. Case, spiders, cross shaft, and bolt cryo treated.
Run in 700 - 800 revs
Unlike most new cases, this one was not as tight with the sides. .
Old May 3, 2024 | 02:43 PM
GTR1999's Avatar
GTR1999
content removed
Old May 3, 2024 | 06:38 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Now that should be one strong posi!
Old May 3, 2024 | 08:19 PM
60 SHARK's Avatar
60 SHARK
Hay Gary,, @ GTR1999,, Stop posting ****,,,😆 🤣😊👍
Old May 4, 2024 | 04:22 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
What's really bad about this car **** is even if you lust for it, you can't have it at any price. These parts are now made of unobtainium.
Sure is pretty thou!
Old May 4, 2024 | 11:37 AM
mikiemike46's Avatar
mikiemike46
2nd Gear
GR8 thread GTR1999,
Can you suggest a few other Vette only forums???
MM46
Old May 5, 2024 | 08:45 PM
7t9l82's Avatar
7t9l82
Originally Posted by mikiemike46
GR8 thread GTR1999,
MM46
There are a lot but unless things have changed this is the most active.
Old May 6, 2024 | 09:29 AM
GTR1999's Avatar
GTR1999
GR8 thread GTR1999,
MM46
There are a lot. I participate in a couple on FB and the tech board on NCRS, but there are many. Some are good and some are not. Some have helpful people but also have some arrogant jerks. So, no I don't really recommend forums or vendors for that matter.
To posi tuned
