Starting Issue
Old May 29, 2024 | 07:46 PM
RFine73's Avatar
RFine73
Default Starting Issue
I have a 1973 L82 with close ratio 4sp. My son and I took the center dash apart to get at the clock and water temp gauges since neither worked. During disassembly, I decided to take the car out on a nice day. I know, a dumb move, as I forgot about the oil line to the oil pressure gauge. About 1/2 way through my drive that small line began spewing oil into the passenger compartment. I got the car shut down ASAP. But after getting things tightened up so I could get the car home, it would not start. No electrical at all.
Well, after flat bedding the car home (thank you Hagerty), getting it clean up (what a mess), and getting the dash put back together it still will not start. I have a new battery and the new clock is still ticking away keeping good time. So I know there is electrical somewhere. My interior lights don't seem to work anymore though. Any thoughts are appreciated.
Old May 29, 2024 | 11:16 PM
Bikespace's Avatar
Bikespace
Have you checked the fuses?
The clutch safety switch may prevent you from starting the car, but is easy to bypass temporarily.
Old May 30, 2024 | 06:58 AM
The Punisher's Avatar
The Punisher
If the car has no electrical at all. Look for the fusible link going down to the starter.
Old May 30, 2024 | 07:49 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Oil sprayed around behind the dash and all over the interior. What did it short out?
start by assessing where you have power, and where you don't.
Old May 30, 2024 | 06:30 PM
RFine73's Avatar
RFine73
I will check the fuses. I have exterior lights, dash lights, horn, etc. I don't have the radio, wipers, or engine starting
Old May 30, 2024 | 08:32 PM
Peterbuilt's Avatar
Peterbuilt
You have 1 fusible link by the starter and another 1 near the horn relay, have you checked that one?
Old May 30, 2024 | 09:22 PM
RFine73's Avatar
RFine73
Will do. Are these located in the engine bay? I think that's what you're saying in your message. I had assumed all the fuses were located under the driver side dash.
Thank you very much,
Craig
Old May 31, 2024 | 01:03 PM
Peterbuilt's Avatar
Peterbuilt
Craig
Glass fuses are found in the fuse box, a fusible link is a wire.
Your horn relay is under the hood and on the left inside fender.
Here's an internet photo of what it looks like:
Old May 31, 2024 | 03:06 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would say that you popped a fuse for the ignition when you were wrenching behind the dash withthe oil line. The ign side of the fuse block has more than one tap on it so you may have more than one fuse gone....All the fuse panel power comes in from the positive side of the starter and the horn relay on older models
Old May 31, 2024 | 07:13 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi again
There is a second fusible link (also at the horn relay) and this one sends power to the ignition switch.
Page 2:
To Starting Issue
