Bench Bleeding Master Cylinder
Old Jun 2, 2024 | 02:10 AM
riverracer au's Avatar
riverracer au
Default Bench Bleeding Master Cylinder
Have a question regarding the bench bleeding of my master cylinder.
Here's a quick video I just took.
EDIT: I cannot get the embedded video to play thru the forum for some reason, please click on the "watch on youtube" at bottom left of video.
I'm not getting any more bubbles out of either the hoses or the tiny holes on the bottom of the reservoir. All good there.
But I do get a little vertical "spurt" from the bottom hole in the front bowl, but no "spurt" or any sign of surface disturbance except out of the bleed hose in the rear bowl.
Is this normal behavior or is the master cylinder showing a problem?
If so, for future reference, which is the correct behavior, spurt or no spurt?
Old Jun 2, 2024 | 03:06 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I've rebuilt more masters than I can honestly remember. Normal is a spurt.
Old Jun 2, 2024 | 09:37 AM
HeadsU.P.'s Avatar
HeadsU.P.
Yep, looks good.
You can do another 10 strokes with the nose down in the vice.
Then another 10, nose up.
Remember. Do Not Shove the Piston In More Than 1 & 3/8 inches.
Or damage could occur to the seals, voiding the warranty.
Leave that bleeder kit in place until you are ready to attach brake lines on the car. That will keep the DOT3 from leaking out.
But regardless, you still have to do a complete 6 bleeder screws flush. You have introduced air bubbles into the system.
Click on my avatar to the left. Look for photo albums, bench bleeding for tips.
Old Jun 2, 2024 | 09:55 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
You may not be pushing quite far enough to see the rear spurt. Just to be sure it's open, stick a paper clip end or the like into the hole to clear it.
That spurting fountain action is what has ruined many fender paint finishes, be careful when the master is on the car and you pump the brakes with no cover on it.
Old Jun 2, 2024 | 05:32 PM
riverracer au
So I gather what everyone is saying, is that I should see some fluids movement in the rear bowl.
I am slowly pushing the plunger in until it stops, haven't measured the actual distance.
This master would be about 10yrs old.
To be safe I'll throw money at it and purchase a new unit from RockAuto and hopefully it will be down here by the end of the week.
Old Jun 3, 2024 | 07:52 AM
HeadsU.P.'s Avatar
HeadsU.P.
Do not turn in your core just yet.
Put the new & old masters side-by-side and compare. Especially at the piston portion.
The design of the rear of the master changed over the years.
It is imperative the new matches the old.
For your sake, let's hope RockAuto has the correct unit.
Some stores data base states: Fits All Vettes from 1800's to 2025, red ones, yellow ones . . . . . PB brakes, manual brakes, no brakes etc.
Old Jun 3, 2024 | 09:44 AM
barkingrats
I could certainly be wrong about this, but here goes anyway...
The front and rear systems do not apply equally. The fronts apply more pressure so more fluid movement is expected. If the rear bench bleed hose is feeding back with a good stream of fluid then I'd not change out the master.
Old Jun 3, 2024 | 10:33 AM
Hopper12's Avatar
Hopper12
I just bench bled the master for our '68 Saturday, so it's fresh in my mind.
  • To avoid pushing the piston too far, I put a small vice grip on the shaft of the phillips screwdriver just short of the 1 1/2" point and that works well.
  • The front and rear 'squirt vs. spurt' was definitely a bit different. When no more bubbles, the rear was more of a 'disturbance' than the occasional squirt from the front.
  • As stated above, I do the master level, then change it a bit so it's higher in the rear, etc. I always get just a few more bubbles when I do that.
  • Also as stated above, don't chuck you old master until you know the rod will be the correct length. I helped a friend chase a brake issue recently after he replaced the MC. He got rid of the core and we found that the new MC had a difference and needed a shorter rod.
Best, Paul
Old Jun 3, 2024 | 01:13 PM
cagotzmann's Avatar
cagotzmann
https://www.youtube.com/watch?v=loKw8c5G-AQ
So here is the last step once you install the MC in the car. YOU WILL GET AIR IN THE LINES.
Here is how I bleed the MC while on the Car. Works very well.
Get the last bit of air out from the brake master cylinder. - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Jun 3, 2024 | 06:50 PM
riverracer au
Spent Sunday trying to get a firm pedal, that's why I thought it could have been the master cylinder.
there are no leaks from any calipers, rears had a couple of replaced pistons and 8 new seals installed about 2yrs ago.
I had a temporary bolt in place of the switch in the front brass distribution block to hold the shuttle from moving/tripping.
tried reverse bleeding with one of those Phoenix V5 units, pedal goes to the floor.
tried gravity bleeding to get the last out at the caliper nipples, pedal goes to the floor,
tried vacuum bleeding, pedal goes to the floor,
tried the rear up higher as mentioned above, still no difference.
at slow speed, car will stop, but I have long pedal travel, ie: it hits the carpet, defiantly no wheel lock up and skid to a stop.
so then i removed the master and retried bench bleeding it, that's when i noticed the spurt / no spurt.
Old Jun 3, 2024 | 07:20 PM
4-vettes's Avatar
4-vettes
Considering everything you have tried. And I believe those reverse bleeders to be very effective.
I am with you. Something must be up with that master.
I also agree with a few of the guys above in that the rear moves less than the front. But you still should see fluid movement. Perhaps the seal between the front and rear pistons is damaged.
At any rate this must be extremely frustrating for you.
Me, I'd be either rebuilding or replacing that master as well. Fingers crossed.
Old Jun 4, 2024 | 12:14 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Do you know anybody with a "power bleeder" you can attach to the MC, and bleed down thru the calipers?
Even though you need to bench bleed the MC, I believe the forced pressure thru the MC will get any small
pockets of air out of the MC.
Motive makes a kit ~ $100.00 USD for the 68-82 vette MC. Motive Products 0252 Motive Products Power Bleeder Kits | Summit Racing
I had so many problems with my brakes, but it ended up being bad rotors (lip seal) that kept causing air to infiltrate
the system. I replaced everything, I got so pissed with the problems I was having.
Too bad you're located so far away, I got a brand new MC from Napa, lifetime warranty, just sitting on the shelf (already bench bled).
To Bench Bleeding Master Cylinder
