Rear spring install
Old Jun 27, 2024 | 02:08 PM
Jackk's Avatar
Jackk
Default Rear spring install
Any tips on how to install the rear spring on my bare frame. The body is off so I need some way to safely compress the spring.
Old Jun 27, 2024 | 03:17 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
How about a 2x4 spanning the top of the frame side to side and using a ratchet strap between the spring and 2x?
Old Jun 27, 2024 | 04:10 PM
Jackk's Avatar
Jackk
I thought about something like that. I have the frame on a ramp lift. I thought I might ratchet strap the frame to the lift and use a jack under the spring.
Old Jun 28, 2024 | 01:34 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
I wedged a 2x4 between the frame and the garage ceiling and jacked the sping end up...
A piece a plywood was mounted to the ceiling to spread thje load across the joists so it wouldn't just pinch through the drywall.
Paui
Old Jun 28, 2024 | 07:46 AM
Jackk's Avatar
Jackk
Thanks for the picture Paul. Looks like you are using two jacks in the picture. I'm guessing one is to lift the trailing arm up to ride height and the other to lift the spring. Did you have the spring fully torqued to the differential when you did this or just snug?
Old Jun 28, 2024 | 08:27 AM
Tampa Jerry's Avatar
Tampa Jerry
Torque the four spring bolts with the full weight of the car. If you torque it before, you run the risk of snapping off the ears of the differential cover. Jerry
Old Jun 28, 2024 | 08:48 AM
69L88's Avatar
69L88
I stacked up my truck winter wheels/tires on the frame to add some weight. Doesn’t take much.
Old Jun 28, 2024 | 09:59 AM
barkingrats
I've read about ratcheting the frame to the lift, especially to simulate the assembled car's weight for setting alignment or some such. I was thinking you were working on the ground where a jack would lift everything before lifting the spring enough to get it connected. I don't see why the jack wouldn't work in this case too.
Old Jun 28, 2024 | 01:55 PM
Bikespace's Avatar
Bikespace
Here's what I did:
I got rid of that heavy steel spring, and used a composite spring instead. Your best option today is likely a low-arch spring from VanSteel.
It'll be slack with the suspension at full droop, so you can bolt the spring to the trailing arms without compressing anything, so it's both lighter AND safer to install.
Old Jun 28, 2024 | 03:36 PM
Jackk's Avatar
Jackk
This is the method that I ended up using. I strapped the frame down to the lift and used the jack to lift the spring. Worked like a charm. The problem I have now is that with the suspension hanging down the axle shafts on both sides are binding against the new side yokes that I installed in the differential and won't turn a full turn. When I measure the old side yokes and compare them to the new ones there is a definite difference in the clearance area for the axle shaft.
Old Jun 28, 2024 | 04:19 PM
barkingrats
Default !
There's always something that crops up as an unintended consequence! What if you were to replicate the jack/jackstands and frame cinching so the half-shafts were pretty much level and then place wood wedges under the trailing arms at the frame?
Old Jun 28, 2024 | 05:04 PM
Jackk's Avatar
Jackk
I think my problem is like so many of us that have to buy aftermarket replacement parts,quality is a big problem. With the suspension hanging as it is the assembly should rotate with no problem. The new side yokes do not have enough clearance for the axle shafts when the suspension is hanging as in the picture. When I raise the suspension with a jack and the axle shaft comes up closer to ride height it rotates fine.The only thing I can think of doing is take my die grinder and provide the clearance required. Jack
Old Jun 28, 2024 | 06:16 PM
Bikespace's Avatar
Bikespace
Who told you that the assembly should rotate without issue while the suspension is at full droop? That is certainly not the case.
With a low-arch composite spring, you can raise the trailing arms a bit before the spring takes any weight, and you may be able to freely turn the assembly then. You can do the same with that heavily arched steel spring, but only if the spring is carrying some of the weight of the car.
Old Jun 28, 2024 | 08:59 PM
Jackk's Avatar
Jackk
The assembly rotated at full droop before I installed the new side yokes. The new side yokes are measurable different than the old ones.
Old Jun 28, 2024 | 09:30 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
You also have new shocks now.
Some of the shocks have shorter extension travel, and the spring will not drop as far.
You don't need 5" of droop anyway, it's a waste, about 2" is enough.
You only have 2" in rebound/bump anyway!
Old Jul 1, 2024 | 01:45 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Here's a link to my build thread covering this. Post #309 has better photos that show what I did...
https://www.corvetteforum.com/forums...post1606675503
The 4 center spring plate bolts were NOT torqued yet...
Paul
To Rear spring install
