Spark plugs!
Old Jul 15, 2024 | 07:37 AM
augiedoggy's Avatar
augiedoggy
Just mentioning again, theres a LOT of fake spark plugs being sold online especially NGK. on other forum people have reported the electrode blowing off and damaging the engine.
There are Many more videos and conversations on other forums
Old Jul 15, 2024 | 07:51 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by Mdbirk
In 2011, Honeywell sold its automotive Consumer Products Group to Rank Group. They no longer own autolite.
Yes I found that also and I mentioned that in the fourth sentence of the text you quoted.
Old Jul 15, 2024 | 08:37 AM
HeadsU.P.'s Avatar
HeadsU.P.
Supposedly the counterfeit issue with NGK was a couple years back.
Hopefully all those sets on the shelf are long gone, destroyed, or no longer being sold.
The first clue was the blurry ink writing on the porcelain.
Second clue was the engraving numbers in the steel.
Old Jul 15, 2024 | 10:02 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by cottoneg
They came out with a new metal I never heard of rutherium!!
Wow...do I pick the DFE or the PSPE design?
Choose to be ruthless!
Old Jul 15, 2024 | 10:08 AM
barkingrats
I don't recall if the counterfeits were found at mainline auto parts stores like NAPA, O'Reilly's, Summit, etc., however, the knowledge that fakes exist always leads me away from Amazon, eBay, and the other generalist retailers for ignition components.
Old Jul 15, 2024 | 10:13 AM
SEVNT6's Avatar
SEVNT6
That's it exactly. If you don't want fakes go to a retail auto parts store..
Old Jul 15, 2024 | 04:26 PM
augiedoggy's Avatar
augiedoggy
Its still a thing.. lots of you tube videos a year or less old about it as well.
Old Jul 15, 2024 | 04:33 PM
augiedoggy's Avatar
augiedoggy
Thats very true. But a lot of people shop online these days because the costs for many things at the autostore are generally higher and it can add up quick..
I bought my last set of plugs from Rock auto and have no concern of getting fakes there myself. I buy a lot of auto parts on amazon and ebay and I cant really recall ever getting ripped off but I tend to try to use common sense and check feedback and forums for heads up like im trying to give here. YMMV sometimes things arent as they seem. Just look at all the folks who bought poly bushings from VBP thinking they were getting quality bushings and they turned out to be garbage the shrunk, hardened and cracked...
Old Jul 15, 2024 | 07:58 PM
Mdbirk's Avatar
Mdbirk
Old Jul 16, 2024 | 08:11 AM
HeadsU.P.'s Avatar
HeadsU.P.
Just because someone opts to buy from local parts store does not guarantee their sparkplugs are 100% the real thing.
All of them: AutoZone, NAPA, Advance Auto, O Reiley's could UNKNOWINGLY get plugs from the same supplier as Amazon unknowingly did.
Who is going to go through thousands of boxes and check the print on the sparkplug porcelain?
No one. That's who.
There are no guarantees in life. More importantly is that we are on to them, for making counterfeit and will be on the look-out.
Old Jul 16, 2024 | 08:25 AM
Mdbirk's Avatar
Mdbirk
No one. That's who.
I think you're wrong, Amazon or rather the "sellers" on Amazon buy cheap and resell. Some are reputable companies. Big chain auto parts store have a supply network, ie they buy and import ngk plugs from Niterra Co., Ltd (the company that makes the plugs).... Somehow someone would need to sneak in counterfeit plugs into the supply chain..... doing your homework is the best option. Look at the reviews, see if there's any pictures with those reviews, look for import info and mostly make sure it's backed by Amazon.
Some time ago on Amazon people were ordering hard drives and what were they receiving in the mail, a brick! A literal brick the same weight as a hard drive.... Wouldn't happen at best buy.
Old Jul 20, 2024 | 09:27 AM
Cam33's Avatar
Cam33
Replacing my spark plugs. Every plug has to be ordered, the only ones in stock off the shelf are champion, autolite and ngk.... Which one should I buy? They're all equally priced.
first off why are you changing them ? Is the a problem with the plugs ? If not leave them alone. My plugs are original since 70 with 33k miles and runs perfectly.. if it ain’t broke don’t mess with it
Old Jul 20, 2024 | 09:33 AM
  #33
Mdbirk's Avatar
Mdbirk
New fuel system, new distributor, new coil and freshly rebuilt engine. Threw the old plugs in and had occasional misfire and hard starting. Tested the plugs with a multimeter and most of them read 3-5, replaced now and it resolved my issues.
Old Jul 20, 2024 | 10:37 AM
  #34
augiedoggy's Avatar
augiedoggy
I believe your correct about this.
I am a member of amazons "vine" program and that en tales ordering, testing and reviewing things for amazon that im basically just paying tax on at the end of the year. They use these methods as well as others reviews and ? to determine what to carry and what not to allow. what I dont care for is the way they sometimes combine the reviews of multiple different products into one..
Old Jul 20, 2024 | 12:00 PM
  #35
JavaJolt78's Avatar
JavaJolt78
FWIW I have always used AC-Delco on my 78!!!!
JJ78
Old Jul 20, 2024 | 03:03 PM
  #36
augiedoggy's Avatar
augiedoggy
JJ78
and I believe the regular copper ac delco "branded" plugs are now made in china by autolite, denso or NGK depending on model for at least the last 7 years or so. possibly since GM went bankrupt and became an international company.
