82 Crossfire injection
Old Jul 29, 2024 | 08:44 PM
jmcdonald62's Avatar
jmcdonald62
4th Gear
Default 82 Crossfire injection
Having crossfire issues. High idle,surging and stalling with flashing CEL. I have done what I think is all the normal repairs for this issue with no results. Can anyone help me??
Old Jul 29, 2024 | 09:22 PM
gjohnson's Avatar
gjohnson
Pull the codes.It will tell you whats wrong.Paper clip method works if you dont have a OBD1 reader
Old Jul 29, 2024 | 09:40 PM
82LS7's Avatar
82LS7
Check TPS voltage at idle, should be around .5 Volt. My fix for that situation was an LS7........
Old Jul 29, 2024 | 10:02 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
So, you didn't say what the code(s) are, what are they and what have you done? If you do not have an 82 GM service manual, GET ONE! You will need it and it is a great manual to have.
Old Jul 29, 2024 | 10:04 PM
jmcdonald62
4th Gear
  • There are not any codes
jmcdonald62
4th Gear
I have replaced the TPS and adjusted
Old Jul 30, 2024 | 11:06 AM
brushmor's Avatar
brushmor
Do you mean there are no codes at all or you are getting code "12"? If it is the former could be leaning towards a bad ECM.
Just in case you don't know, you read the codes with key on engine off. If you try reading the codes with the engine on you are in field service mode and flashes are something different.
Old Jul 30, 2024 | 01:55 PM
Buccaneer's Avatar
Buccaneer
Am I assuming correctly that you have an 82 GM service manual?
Old Aug 1, 2024 | 05:55 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
To 82 Crossfire injection
