A new record: 60-second job becomes…
Old Aug 4, 2024 | 04:46 PM
71 Vert LS1's Avatar
71 Vert LS1
First time I've been called "clever". Lots of other names but not clever. LOL.
Old Aug 7, 2024 | 10:46 AM
kossuth's Avatar
kossuth
Originally Posted by Richard454
I would not use a rivenut- it needs to be tight and a difference in material ( aluminum) could come loose and really wreck you day out driving.
Better/way easier than welding
I would get a longer bolt- with a star washer- clean up the hole for a good fit.
With some wire /tape - feed the wire from the back side hole in the frame and pull it though-
A jam nut would be preferred to hold in place- but regular bolt is fine.
Then bolt down the cable end wit another star washer.
I guess you didn’t read where I referenced the proper one to use here.
Old Aug 7, 2024 | 11:31 AM
OldCarBum's Avatar
OldCarBum
Here is a photo of my paint matching the powder coating.
Old Aug 7, 2024 | 02:20 PM
DorianC3's Avatar
DorianC3
Quite stunning work there, OldCarBum
Old Aug 7, 2024 | 10:44 PM
Mooser's Avatar
Mooser
Old Aug 7, 2024 | 11:14 PM
DorianC3's Avatar
DorianC3
Old Aug 8, 2024 | 09:15 AM
Richard454's Avatar
Richard454
I saw that-The negative battery ground is crucial-
I'm still not a fan of using a rivenut for a high torque - large size application.
And rivenuts work much better (spin out) in a softer metal such as aluminum.
Old Aug 28, 2024 | 05:24 AM
DorianC3's Avatar
DorianC3
I just wanted to circle back with the solution.
my welding skills are mediocre but this worked great
Old Aug 28, 2024 | 07:23 AM
drwet's Avatar
drwet
That’s what my dad used to call gorilla welding. Ugly but strong.
Old Aug 28, 2024 | 03:00 PM
DorianC3's Avatar
DorianC3
To my credit it was under the car on my back with very little space. Tried to make it as pretty as I could
