1971 Base 350 Timing
Old Aug 16, 2024 | 01:46 PM
jbakyy's Avatar
jbakyy
Default 1971 Base 350 Timing
Hello,
how far off can the timing be on my 1971 base engine. I am timing at idle 8 degrees, will the car run bad if I’m off just a couple degrees? Car been running great but went wacky this morning hesitating and wanting to stall. Dwell was good and timing may have been off a few degrees. Would being off just a few degrees make it run poor. Thanks
Old Aug 16, 2024 | 02:29 PM
REELAV8R's Avatar
REELAV8R
Is that 8* with vacuum advance removed? Are you using port or manifold vacuum for the vacuum advance?
Could be your vacuum advance diaphragm has failed. When you start moving and add throttle the vacuum should advance the timing whether port or manifold is being used.
Old Aug 16, 2024 | 06:15 PM
rcread's Avatar
rcread
You should time it with the vacuum advance removed from the distributor and plugged and the springs removed from the advance weights in the distributor. Total timing, ideally, should be 36° with this done. A few degrees off won't have a huge effect on the engine, but it may be noticeable to you.
Old Aug 16, 2024 | 07:02 PM
HeadsU.P.'s Avatar
HeadsU.P.
jbakyy,
I take it you have been making adjustments turning the distributor.
Grab the entire dist unit and see if it will budge. Sometimes we think we torqued down the dist clamp, and it's not tight.
Who says its IGN? Could be a fuel issue.
What carb? Fuel filter clean?
Old Aug 17, 2024 | 06:00 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Have to agree, could very well be something completely unrelated to your distributor. Yes, certainly check your timing, your advanced timing, when it's all in. Ya know, the basics there. Simply checking idle timing isn't really doing very much however. Then plug the vacuum advance canister back in. Check that.
If that all checks out. Then start looking at other possibilities, as in the more likely possibility that something is up with your carb.
Old Aug 18, 2024 | 08:35 PM
jbakyy's Avatar
jbakyy
8 with vacuum tube removed and plugged. Thanks
Old Aug 18, 2024 | 08:37 PM
jbakyy's Avatar
jbakyy
Thanks the tube was removed and plugged
Old Aug 18, 2024 | 08:39 PM
jbakyy's Avatar
jbakyy
Good point and thanks. What’s your favorite fuel system cleaner? Lucas or seafoam?
Old Aug 18, 2024 | 08:40 PM
jbakyy's Avatar
jbakyy
Old Aug 18, 2024 | 08:43 PM
lars's Avatar
lars
Don't use that crap. I rebuild more carbs as a result of that stuff being used than for any other reason. Completely unnecessary and useless, and it screws up a carb bad.
You're leaving a lot of performance on the table by timing the engine at 8 initial without checking total.
Old Aug 19, 2024 | 09:04 PM
jbakyy's Avatar
jbakyy
thanks
Originally Posted by HeadsU.P.
jbakyy,
Old Aug 19, 2024 | 09:09 PM
jbakyy's Avatar
jbakyy
Thanks my car has no performance maybe 300 hp with base 350. Not 400 hp like your l79 c2.
Old Aug 20, 2024 | 07:44 AM
bonesbrakr's Avatar
bonesbrakr
If it was running fine and then all of a sudden went "wacky" then you probably have a issue besides timing. Unless the hold down clamp was loose and the distributor turned.
Bad gas?
Clogged fuel filter?
Crack in a rubber gas line?
Original carb?
Old Aug 20, 2024 | 12:47 PM
7T1vette's Avatar
7T1vette
If all you want to do is set "initial" timing, do yourself a favor and time it at 12 degrees BTDC (compression stroke) with distributor advance plumbing removed and capped to prevent vacuum loss. The 8 degrees recommended by GM detunes the engine for BEST WARRANY COST SAVINGS and for compliance with EPA requirements.
If you really want to do the job properly, get Lars' paper on setting timing for performance and follow it exactly.
Old Aug 20, 2024 | 06:47 PM
jbakyy's Avatar
jbakyy
Thank you
tQUOTE=bonesbrakr;1608097690]If it was running fine and then all of a sudden went "wacky" then you probably have an issue besides timing. Unless the hold down clamp was loose and the distributor turned.
Bad gas?
Original carb?[/QUOTE]
Old Aug 20, 2024 | 06:49 PM
jbakyy's Avatar
jbakyy
Very interesting, thank you 7t1
Old Aug 20, 2024 | 06:53 PM
jbakyy's Avatar
jbakyy
Thank you, I think my problem was to much timing around 24 degrees and also low amounts of gas causing some pickup problems.
Old Aug 25, 2024 | 07:04 AM
jbakyy's Avatar
jbakyy
Yes and thank you, car ran bad yesterday. It’s not timing, running good and then went wacky running bad, missing stalling. Carb is quadrajet and I think original. I’m guessing fuel problem and will probably start with fuel filter.
Old Aug 28, 2024 | 06:09 PM
jbakyy's Avatar
jbakyy
thanks carb is quadrajet and fuel filter will be my next effort to try and fix.
QUOTE=HeadsU.P.;1608088396]jbakyy,
What carb? Fuel filter clean?[/QUOTE]
To 1971 Base 350 Timing
