Slop on Borgeson steering box
Old Oct 19, 2024 | 11:27 AM
B's Avatar
B
Default Slop on Borgeson steering box
See attached.
I installed the Borgeson box recently and it seems to have a bunch of slop in it (at least to me). I can turn the wheel maybe 1/2 to 3/4 inch before the box engages which turns the car. You can see in the video that the steering column moves the spline in the box but the tires don't move.
I've read a couple threads but most of the issues i see are elsewhere in the steering (column, pitman arm, bushings etc). I also saw how to adjust the box itself, which maybe solves my problem. The fluid is full and i bled the air from the system.
So.... does this seem normal, should i just adjust the box??? Thoughts?
Old Oct 19, 2024 | 12:06 PM
zwede's Avatar
zwede
My box came from Borgeson adjusted wrong (loose). A small adjustment of the adjustment screw on top of the box and it has been fine for several years now with no slop.
Old Oct 19, 2024 | 06:16 PM
GTR1999's Avatar
GTR1999
If that is at high lash, then it looks pretty lousy for a new or rebuilt box to me
Old Nov 14, 2024 | 07:54 PM
KENS80V's Avatar
KENS80V
In the video you can see the rag joint swivel but not the steering gear shaft. The problem is with the fit between the two.
I'll bet the rag joint end they gave you is 3/4"DD (should be 18mm DD) or you haven't tightened both set screws down before the video was shot..
To Slop on Borgeson steering box
