Torque question
Old Nov 12, 2024 | 03:47 PM
Cam33's Avatar
Cam33
Default Torque question
Hi I was buttoning up things on suspension and chassis and noticed the shifter levers had some play to them . Can anyone tell me if that is correct, or they should be torqued or snugged . Thank
you
Old Nov 12, 2024 | 08:56 PM
MelWff's Avatar
MelWff
Impossible to tell how much play you have from a still picture. Put a wrench on the nut and see if it is loose.
Old Nov 12, 2024 | 10:17 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The levers shouldn't be loose on the side cover fork studs. They need to be securely attached to the threaded studs.
I looked through the service and overhaul manuals for '63 & '72 and don't see any torque specs for the levers' nuts on the side cover. The cover itself is secured at 15-20 lbft so that's probably a safe number to use on the levers.
Old Nov 12, 2024 | 10:26 PM
barkingrats
Found this AIM diagram inside another thread on the Muncie 4-speed. The torque spec for those bolts is 15-24 lbs ft.
Old Nov 13, 2024 | 01:26 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
There is always some wobble, but if the rather short stub shaft is loose in the case, that is a bushing problem.
And since your pic is oily, and the seals may be leaking, check that.
Old Nov 13, 2024 | 04:01 PM
Cam33's Avatar
Cam33
thank u sir much appreciated 👍
Old Nov 13, 2024 | 04:03 PM
Cam33's Avatar
Cam33
thank u I will
Old Nov 13, 2024 | 04:29 PM
60 SHARK's Avatar
60 SHARK
In your pic,,, the lock washer appears to be flat. (locked) . And 15-25lbs or less will 'lock' the washer. If the arm seems loose, im guessing its not the nuts and washers.
To Torque question
