Trigonometry and Toe Plates
Old Dec 9, 2024 | 09:51 AM
JCurtiss's Avatar
JCurtiss
Default Trigonometry and Toe Plates
Toe plates are an inexpensive and accurate tool for adjusting front and rear wheel toe on our cars, but many folks use them incorrectly, resulting in a fairly significant error.
Prescribed toe specifications are based on the difference between the front and back measurements across the diameter of the rims. In contrast, toe plates have measuring slots that are typically spaced considerably farther away than the rim diameter. For instance, the spacing between my toe plate slots is 22” and measuring the toe using 22” slot spacing will not be the same as measuring toe based on, say, a 15” rim diameter (my '76 C3). For example, 1/16” (0.063”) toe-in based on 15” diameter rims becomes 0.094” when measured using 22” toe-plate slot spacing. The result is an error of 0.031”.
To achieve accurate results using toe plates you must take into account the difference between slot spacing on the plates and the rim diameter. First, trigonometry is used to determine the toe angle based on the rim diameter and the prescribed toe in fractions of an inch. This angle is then used to determine what the prescribed toe will become when measuring with toe plates.
I hope this helps folks to use toe plates correctly.
Jason
Old Dec 10, 2024 | 06:10 AM
sleepchamber's Avatar
sleepchamber
We need some visual references to complete the lesson please.
Old Dec 10, 2024 | 01:31 PM
SteveG75's Avatar
SteveG75
Isn't the stock toe based on the 27" tire/wheel diameter, not just the 15" wheel diameter?
Old Dec 10, 2024 | 03:33 PM
Gale Banks 80''s Avatar
Gale Banks 80'
This is a question I have always wondered and have never got an answer for. Alignment specs of 1/8" Toe in is the same for a C1 and a C8 Corvette despite vastly different tire and wheel combinations. When I do an alignment, I start with the rear and mark out a 28" section on the frame. ( I just picked 28 inches' because I don't what the real number should be ) I shoot a lazer and set my rear toe in measuring off the frame. I then shoot a Line to the Front Axel and make a note of what the distance is. Then I go to the other side and don't mark the Frame I just make Toe in the same as the other side using the distance off the Front Axel.
I then do the opposite for the Front, I shoot backwards to my 28 inches on the Frame and then measure the distance off my rear Axels. This gets more complicated due to my suspension changes because my cars are not square, in other words my Axel Widths are not the same front to rear.
Old Dec 10, 2024 | 07:51 PM
JCurtiss's Avatar
JCurtiss
Here's a rough sketch that shows the problem if you don't take into account the length of the toe plates.
Jason
File Type: pdf
Old Dec 10, 2024 | 08:01 PM
JCurtiss's Avatar
JCurtiss
Toe is based on rim/wheel diameter. Alignment machines use "targets" that are attached to the rim for checking and adjusting toe.
Jason
Old Dec 10, 2024 | 08:22 PM
Kilobuck84's Avatar
Kilobuck84
Considering that they don't make calipers big enough to measure the track width of a car and these things are getting done with tape measures I suspect you guys are cutting it a little too fine. But if it makes you feel better, have at it.
Old Dec 10, 2024 | 09:18 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I think it's just terrific that Jason assumes that we all align our cars incorrectly. And have no idea how to correctly use tools.
Old Dec 10, 2024 | 09:28 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Ummm... toe-in is measured in inches at the tire tread, not the wheel rim.
According to BFG Racing Tire guys who trained me, and other racing groups.
The rim is just a convenient locating point.
But the confusion over that very issue is probably why they switched to measuring toe-in in degrees at some point.
And if you are measuring it in degrees, it does not matter where your locating / measuring points are.
Old Dec 11, 2024 | 08:21 AM
JCurtiss's Avatar
JCurtiss
I apologize for upsetting you.
Jason
Old Dec 11, 2024 | 10:57 AM
SteveG75's Avatar
SteveG75
So, Van Steel has alignment charts for the C3 in both degrees and inches. I did the math last night. They are using 27" as the diameter.
https://www.vansteel.com/PDFs/alignm...82-degrees.pdf
https://www.vansteel.com/PDFs/alignmentspecs6382.pdf
Old Dec 11, 2024 | 11:19 AM
stingr69's Avatar
stingr69
Jason
Great concept but .....The difference seen by taking the measurement at the plates vs taking the measurement at the rim is not shown..... Show us the math. The difference is too small to see with a tape measure. Not enough precision.
Not really an issue either as we are using "custom" specs that were not measured or provided "at the rim".
Angle specs are more precise and can be calculated no matter how long the plates are. Longer the plate, the better the precision will be.
Old Dec 11, 2024 | 03:01 PM
JCurtiss's Avatar
JCurtiss
Here you go.
Yes, the difference is quite small ~1/32" but the error increases when using the same toe plates with smaller wheels, such as the 14" wheels on my '66 MGB.
Jason
File Type: pdf
Old Dec 11, 2024 | 04:29 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
But toe-in (using the unit of inches) is measured (or more correctly reported) at the tire tread, say ~27".
Anything reported at 22" or 15" or 14" is not correct.
You are correct the math does not work out the same at the various distances.
This "toe-in at the rim" myth has been around for ages.
It happens because that is where most of the equipment attaches.
But examine their charts, or the calculations, and the reported measurement works out to the tire tread distance.
And some people just calculate it wrong.
If you do not want to listen, to either reasoning, or experience, I'm done.
Old Dec 11, 2024 | 05:29 PM
stingr69's Avatar
stingr69
Here you go.
Jason
Not quite.....we set the total toe-in at .0625" either way.
​​​​way so .031" per tire....
The difference is not measurable.
Old Dec 11, 2024 | 05:41 PM
JCurtiss's Avatar
JCurtiss
That was my main point: you cannot measure toe accurately with say a 22" toe plate without accounting for the difference between it and the tire or wheel diameter, whichever is appropriate for your vehicle alignment specifications.
Measuring toe at the rim is not a total myth; see the attached.
Jason
File Type: pdf
Old Dec 11, 2024 | 06:03 PM
JCurtiss's Avatar
JCurtiss
I disagree.
Calculate the toe angle on your left-hand sketch and then calculate the toe angle in the right-hand sketch and you'll find quite a difference between the two angles. I calculated the following: left toe angle = 0.081^0 and right toe angle = 0.12^0.
Jason
To Trigonometry and Toe Plates
Old Dec 12, 2024 | 10:46 AM
stingr69's Avatar
stingr69
Jason,
If we want to adjust for the 22" toe boards.....What is the correct toe measurement (in inches) with the longer 22" toe boards if you are shooting for your "true" 1/16" toe-in at the 15" rim?
Old Dec 12, 2024 | 11:41 AM
Golferdad's Avatar
Golferdad
Well,just curious if you wider tire on rear,of course,I guess those dots you have on your sketch is on frame,I think it makes since. Thanks
Old Dec 12, 2024 | 12:44 PM
laz749's Avatar
laz749
Do you set toe individual of each other or together?
