Oil change
Old Jan 24, 2025 | 04:44 PM
marciatoby's Avatar
marciatoby
Default Oil change
If you only drive your vette maybe 500 miles a year and the rest of the time it is in the garage, how often should you change your oil?
Old Jan 24, 2025 | 09:53 PM
kkupec02's Avatar
kkupec02
I do once a year regardless of miles
Old Jan 24, 2025 | 10:57 PM
Since the vast majority of your posts have been in the C3 sections, moving this thread to C3 Tech.
Old Jan 24, 2025 | 11:09 PM
MelWff's Avatar
MelWff
Modern oil change monitors that detect very little usage display change oil now at one year.
Old Jan 24, 2025 | 11:21 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
My engine builder recommended every 2 years for the oil and 4 years for the filter – that's driving 500-1000 miles a year. One caveat is that the engine is never started unless it has the opportunity to reach full operating temps to evaporate moisture. Acid-forming condensation in the crankcase is detrimental to the oil and bearings.
Old Jan 24, 2025 | 11:25 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The real problem here is that you are not out enjoying your car nearly enough. Get out and drive it! It's good for your soul!
If actually using the car just isn't possible, concider selling it to someone who will. It's bad for a vehicle to just sit.
And, change the oil once a year. The trans and diff every 5 years. Brake fluid every 4 years.
Old Jan 24, 2025 | 11:58 PM
7T1vette's Avatar
7T1vette
Depends on whether you are using organic (dino) oil or full synthetic. I would not run dino oil more than a year. It oxidizes with age and loses lubricity, etc. Full synthetic does not have such issues. It must be said that HOW you use your car WHEN you drive it matters, also. If you let the car get fully warmed up and allow any collected condensation to clear from the crankcase, then good for you. If you just fire it and allow the battery to recharge for a couple of minutes....not so good.
If you manage your engine well, full synthetic could be good for a couple of years or more. However, because of the value of our collector vehicles, I usually change oil every year with the full synthetic oil I use. Maybe not "necessary", but I know that it COULD be a benefit....somehow.
P.S. When I did use organic oil, I would always change oil/filter every 3000 miles (maximum) or every 3-4 months.
Old Jan 25, 2025 | 10:01 AM
JavaJolt78's Avatar
JavaJolt78
I live in central Delaware and change it seasonally regardless 2X
JJ78
Old Jan 25, 2025 | 11:23 AM
barkingrats
JJ78
Seriously, every 3 months no matter the mileage or run-time?
Old Jan 25, 2025 | 11:29 AM
JavaJolt78's Avatar
JavaJolt78
What I meant was 2x a year and here that is seasonal!!!
JJ78
QIK59's Avatar
QIK59
Nuts eh ?!
Old Jan 25, 2025 | 11:30 AM
QIK59's Avatar
QIK59
Hloey crap - you must have nothing better to do.
In my C1 I only change tranny /rear end lube when I change tranny's or diff' - so far 5 - 10 years due to ratio changes.
Brake fluid only if I actaully redo brake hoses or wheel cylinders 10 - 20 years at times LOL
Old Jan 25, 2025 | 11:46 AM
QIK59's Avatar
QIK59
And you're in Australia !
I would think the ideal climate as far as any condensation issues in your fluids ??
To Oil change
