Timing Problem
Old Jan 27, 2025 | 10:05 PM
RWBaker's Avatar
RWBaker
Default Timing Problem
I love everything about the 427 in my 69, except for one little problem. Space. It is so painful to do anything to that engine with such a cramped engine bay. I got my timing light out to set the timing and found that I cannot see the timing marks due to the pulleys in the way. What is the secret to being able to see the marks? This car does have AC and power steering.
Surely there is some secret pro tip hiding out there!
Thanks,
Rick
Old Jan 27, 2025 | 10:32 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
My '72 is a BB with PS and A/C... there is no secret that I know of. I lean way over the fender and look down from above. It's quite the exciting time with the A/C's tipped fan propeller-ing just a foot from my face!
Maybe rig up a camera or borescope to see the timing tab?
Old Jan 27, 2025 | 11:35 PM
pltmgr's Avatar
pltmgr
I have a 68 and a 71 with BB's. Both have PS but neither have AC. All my timing marks are clearly marked with white paint which makes it easier for me to find the marks after finding the right angle to point the light.
Old Jan 28, 2025 | 07:33 AM
ctmccloskey's Avatar
ctmccloskey
I have no problems seeing the timing marks on my 1968 C3 BB but then I have no AC either. I am using a serpentine belt conversion on the 427 and it leaves lots of room in the engine compartment. Having a marked balancer is great unless the balancer is made of a ferrous metal. I have a mark on the balancer where I previously had set the timing. Now the Holley Stealth Sniper controls the timing.
This is the first time I have ever heard of a 1968 or 69 C3 BB equipped C3's had a tight engine compartment. On my C3 I can get to all 8 spark plugs from above the engine in less than 20 minutes.
Old Jan 28, 2025 | 09:42 AM
barkingrats
Shirley you jest, sir!
Old Jan 28, 2025 | 10:15 AM
62corvette's Avatar
62corvette
My 71 LS5 w/ac and ps is difficult to see the timing mark, so I empathize with you. Marking the balancer and the timing tab are good ideas, but not easy to do, either. Then you have to get just the proper angle to see it. Watch out for the fan blades! Good luck, and be careful.
Old Jan 29, 2025 | 08:15 AM
stingr69's Avatar
stingr69
Loosten the fan belt long enough to set the timing, then tighten up when finished. Just safer that way.
To Timing Problem
