Amp gauge concern
The fan that you are adding won't have its current running through the gauge unless you deliberately do so. That would be particularly unadvisable. the downside is you won't see any measurement on the gauge associated with the fan.
I switched over to measuring voltage instead of current. I'd rather have the amperage but wasn't willing to try duplicate what the Chevy engineers did.
If you really want to keep your amp gauge you can. I ran a new 6-gauge lead from the Horn Relay to the Starter Post and just redid the Ammeter leads such that they're still in parallel with the new 6-gauge lead. I did NOT calculate but just slapped it in and redid the termination points. Works fairly well and let's me know when I'm having a drawdown.
"The golden rule of batteries is to avoid extreme charge levels — neither fully charging (100%) nor deeply discharging (0%). Instead, keeping the charge between 20% and 80% helps reduce stress on the battery and slows down degradation."
I don't understand why many of us think they need to put a huge output alternator on the older Corvettes. I too have a 1968 C3 and I have a 105 amp alternator on my engine along with 2 Spal 11" fans, MSD ignition system and a complete EFI system and other accessories. I have never had any issues and I keep my fans running after shut down for a few minutes.
If you run the wire from the alternator Output directly to the Starter Motor's Positive Post you will be fine. From there the two fusible links supply the power to the Horn relay so the interior will have full power but the majority of the power will be sent directly to the battery. With the factory wiring and the current sent to the starter post from the new alternator you should still have a fully functional ammeter. My fans together can pull more than 40 amps so I have them wired to a separate fuse block that is connected directly to the battery itself. I also have a electric fan controller that starts the 2 electric fans at 50% power and slowly bring the speed up if and when the engine continues to get hotter. No spiking the electrical system at any time. I don't need to see the fan power going through the ammeter, so I don't this way. Nor do I see the power going to my EFI control system but who cares?
I agree that a Voltmeter would be 100 times more valuable than an ammeter. I have one that plugs into my cigarette lighter and shows me the battery voltage whenever I want to know what it is.
One thing that you might think about is putting an inline fuse in the output of the alternator when you have that much power coming out of it. On my C3 I am using Marine Grade circuit breakers which are water resistant and reliable in environments like a Corvette convertible. I have circuit breakers for my Fan power and one for the battery itself.
Running all that current through the 40 amp shunt and the dashboard wiring could get ugly as that much power going through the thin wires will make resistance and that makes HEAT. Heat and the potential for an electrical fire is a great reason to NOT run the excess power through the shunt and dash. I suspect that with all that power being fed into the car's electrical system through the shunt might turn the shunt into a "Fuse". Me, personally, I don't want all the power going through the dash board area and wiring. This is why we connected the power output from the alternator output directly to the battery (+) post on the starter. My C3 was "loaded" for a 1968 and it came with a 63 amp alternator. That 63 amps was enough to keep my 427 running and all the accessories with it. The MSD ignition box needs some power at higher RPM's and then my Cooling fans started to make the system marginal. This is why I went to a 105 amp 1-wire Powermaster alternator and I have never needed anything larger. Even driving with my headlights on for many hours never presented any problems for the original alternator and the battery/
Remember that bigger output alternator will draw more power from your engine while it is running. It takes More HP to make more electrical power and that is a waste when you don't need it.
A "Loaded" 1968 C3 means PB, PS, PW and a push-button AM/FM single speaker radio. The 1968 C3 was not made to be a "comfortable" Corvette with tons of accessories that suck power. It was a Big powerful engine, four speeds and great brakes, all made for one purpose, To Go Fast!
The alternator will only supply the amps demanded of it. Can't really be "too" big. Just ensure that have adequate fusible links and/or fuses installed for protection. There lies the rub.
I recommend going with a the DR44G. You may have to modify/create the bracket but the voltage control available is quite wonderful. Let me find my long windy link where I installed mine.
Here you go. See link below. I've been upgrading for decades..... first to a 94 amp 12si, then a 140-amp CS-144, and now the ~140-amp DR44G. I really, really, like the voltage control I have over the DR44G.
https://www.corvetteforum.com/forums...xperiment.html
P.S. If you completely replace the main power line in the car, your ammeter will no longer function. If you ADD an additional power line in parallel to the original, you will have the power handling capability you need, but still retain a working ammeter. Or, if you go the full-replacement rounte, you can install the voltmeter with appropriate wiring to it.
As I mentioned above you can keep your ammeter after you run a new lead......if you want to. It ain't rocket surgery. If you really want to know how just let me know.
https://www.corvetteforum.com/forums...post1608694782
Some require that you change from an ammeter to a voltmeter.
My Powermaster alternator required that I swap to a voltmeter.
Corvette Central makes voltmeters to exactly match the design and face of your original ammeter.
Pay particular attention to the wiring requirements of the new alternator and voltmeter.
The power coming from the alternator's output needs to go to the battery thru large enough wires not to make things overheat. This is why we run the alternator output directly to the starter motor's Battery (+) post and secure it there. If you took that large cable and tried to push the power through the shunt then there will be problems. You should not push 150 amps through a 40 amp shunt.... or through 12-16 gauge wires.... If you try you might not like the results.
The horn relay still has battery power going to it from the battery (+) post on the starter motor through the fusible links. Without power going to the horn relay your car will have no power at the fuse block or in the interior of the car.
What would "require you" to install a Volt meter over the existing Ammeter when using a Powermaster brand alternator?
"For FLA (flooded lead-acid) batteries, a common charging rate is around 0.15C (15A per 100Ah) for the bulk charge to 80%, followed by a reduced rate (3A to 5A per 100Ah) for the finish charge, which is crucial to prevent overheating and gassing. If this is the correct and proper method to charge an FLA battery then what happens when you have 150 amp alternator on a 100 amp hour battery? Too large an output of an alternator will cook a battery and boil it dry of any electrolyte. The charger in question charges at 90 amps at idle so it claims, and the typical C3 battery is about 100 amp hours in capacity. Not a good match between the alternator chosen and the battery used."
"The charging rate for flooded batteries is typically expressed as a percentage of the battery's capacity (C-rate). The recommended charging rate for flooded batteries is generally less than 10% of their capacity. For example, a 100Ah flooded battery should be charged at a rate of 10A or less."
A battery should be charged at a rate of approximately 1/10th of its capacity (C/10) for lead-acid batteries, while lithium-ion batteries can handle faster charging, often up to 1C or even higher.
All this is information is readily available at the Battery University or just in Google searches.
Now you will know what your alternator is doing.
If you go with an 100 or 150 A alternator, by the plug and play bypass for the voltage meter. Also run an 8 gauge wire down to the terminal your alternator used to go to on the starter. Tape off the old wire or remove it
