80-82 raised diff
From what I can tell, raising a batwing diff isn't very common. Van Steel said I'm only the second person to ever ask about it. The only info I can find on raising one of these is Bee Jay installing his 1/2" higher than normal. His car didn't come with a batwing, though, so that's a bit of a different situation.
The aluminum pieces aren't hard to make, just some simple lathe work to replace the bushings:
The front puck will be even simpler, basically an 1/8" thick washer. I'll either make that or see if the hardware store has a washer with the necessary dimensions.
From there I've got 3 options, in order of complexity:
1) Drill the center hole offset in my new "bushings". I like this option because it's very simple. I don't like this option because lateral forces will impart a rotational moment on the off center bushings and I'm concerned they could potentially rotate within the batwing.
2) Make the new "bushings" with a center hole and drill a new hole in the frame mount that's 1/2" higher. I'd need to weld on a doubler plate of sorts to the frame mounts since the new hole will overlap with the existing one but that's easy.
3) Cut off the frame brackets and weld them back on 1/2" higher. Basically what Bee Jay did except I won't be starting with the iron diff crossmember design. This would be the cleanest but the most work.
I'm leaning towards option 2. This is a driver, not a show car, and functionality is more important than how it looks. I believe this path will be just as structurally sound as option 3 with significantly less work.
I'll post updates over the next few weeks as I work through getting this installed.
Check with Gary "The" Differential expert on this modification because he might know something that could help you.
I would be very surprised if GM made your new suspension parts and threw them all away before starting on the C4 design. When I upgraded to polyurethane I was trying to make the handling a bit tighter and it worked well. As I get older, I wish I had used the rubber bushing instead. They ride better and last a long time if not neglected.
Being able to mill and machine the Delrin easily is a big plus for prototyping. Why re-design a part when someone already makes it? There are so many catalogues like McMaster-Carr who carry a zillion parts designed for a lot of applications.
Interested to see if your poly bushings seem to add chassis stiffness
