C3: Carb trouble
Old May 3, 2025 | 11:22 PM
74Stm's Avatar
74Stm
2nd Gear
Default C3: Carb trouble
I’m having a bit of trouble, I have 74’ C3 with a pretty new Edlebrock 1406. The problem I am having is when I shut off the car it kinda diesels and when it finally turns off it just sprays fuel from the carb. I think this might be a timing issue but have no idea, any thoughts? I have a video for reference (sorry for the low quality)
File Type: mov
Old May 3, 2025 | 11:33 PM
lars's Avatar
lars
Run-on after shutdown is caused by excessive idle speed (excessive throttle opening) at shutdown. Either lower your idle speed, or fix your timing so you can decrease the throttle opening at idle.
Old May 4, 2025 | 08:31 AM
Fly skids up!'s Avatar
Fly skids up!
Lowing the idle will help stop the run on. But the real cause is another ignition source in the combustion chamber other than the spark plugs like hot spots from carbon build up. Get a can of "Mopar combustion chamber cleaner". It's a little hard to find but that stuff really works. I've heard that using too hot of a spark plug can cause run on but I've never seen it personally.
Old May 4, 2025 | 09:05 AM
7t9l82's Avatar
7t9l82
I remember back in the day when politicians fancied themselves automotive engineers . The forced emissions equipment on cars and they practically all ran like that.
Old May 4, 2025 | 09:19 AM
Bikespace's Avatar
Bikespace
What is your timing set to? If you can't lower your idle, check for vacuum leaks. I'll hold off on bashing that carb until after the obvious fixes.
Did anyone else watch the video? That's not run-on. Or if it is (and your car runs?), perhaps one or more intake valves are stuck open? Have you done a compression and/or leakdown test?
Old May 4, 2025 | 11:18 AM
lars's Avatar
lars
The video isn't viewable in that weird HEIC Apple-only format to most people with "normal" computers...
Old May 4, 2025 | 11:53 AM
Bikespace's Avatar
Bikespace
Works with VLC Player.
OP, can you post it to YouTube?
Old May 4, 2025 | 05:08 PM
Fly skids up!
The video quality is terrible. Looks like it was taken from a third story window and sounds more like hard starting than a run on.
Old May 8, 2025 | 01:48 AM
Cajzmere's Avatar
Cajzmere
That's not run on or "dieseling", that's way off timing or something. That backfire out of the carb is very telling.
Old May 9, 2025 | 05:56 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
My 2 cents ,always listen to Lars,always.
Old May 9, 2025 | 06:16 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
To C3: Carb trouble
