1982 starting issues
Old May 11, 2025 | 05:57 PM
tjmullen56@yahoo.com's Avatar
6th Gear
Default 1982 starting issues
I’ve had ongoing staring issues on my 82 after driving awhile it won’t start until it sits for awhile anywhere from 30 minutes to an hour. There’s no clicking just the dash lights come on and it makes no attempt to start, I replaced the starter solenoid and starter cable early last year worked great until last fall when the issue started again over winter I replaced the ignition switch and the stater interrupt everything worked great until today and the issue started again. Any ideas would be helpful
Old May 11, 2025 | 06:31 PM
TorchZ51's Avatar
TorchZ51
Check the 6 pin connector located close to the heater box - passenger side. The power from the 2 fusible links and starter (purple wire) goes through that connector. I had an intermittent issue and found the connector melted.
Old May 11, 2025 | 07:09 PM
HeadsU.P.'s Avatar
HeadsU.P.
TJMullen,
Are headers involved here?
Is there some type of starter heat shield, wrap, etc?
When you replaced the solenoid, did you purchase the Heavy-Duty ceramic end cap unit?
Is there a GRD cable from starter to frame?
Old May 11, 2025 | 07:24 PM
6th Gear
No headers
there is a small heat shield on the starter but no wrap
No on the ceramic solenoid
checked the cable all looks good
thanks
Old May 11, 2025 | 07:49 PM
Fly skids up!'s Avatar
Fly skids up!
Next time it happens rap the starter with a hammer and see what happens. Most people don't realize that the pull in coil in the solenoid grounds through the brushes/commutator.
Old May 11, 2025 | 08:15 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
It sounds and looks like you have a bad starter. Try the hammer, if it starts you know what you have to do. The hammer trick usually works in that situation, but not 100%.
To 1982 starting issues
