Curtesy light wiring
Old May 27, 2025 | 10:40 AM
talc's Avatar
talc
Default Curtesy light wiring
Hi Guys, There has been a few threads on this subject, but I have something a little different. I have a 74 coupe. They have decided to stop working. The orange power wire goes to the lights and then goes through the firewall. The orange power wire coming from the fuse box (cig light) comes out and goes through the firewall as well. Any one know where they go and if they meet up.? wiring diagram say that neither of them should go through the fire wall.
Old May 27, 2025 | 11:33 AM
69L88's Avatar
69L88
Those circuits do not go through the firewall.
Have you checked the fuse?
Old May 27, 2025 | 01:02 PM
ZIOGEO's Avatar
ZIOGEO
69L88 is correct, that circuit should not go through the FW.
If you remove one of the courtesy bulbs you should have +12V at the socket.
The clock and cig lighter are also on the same circuit.
Old May 27, 2025 | 03:22 PM
7T1vette's Avatar
7T1vette
The door jamb switches pass electrical GROUND to the courtesy lamps...which already have 12 vdc power connected to them.
Old May 27, 2025 | 03:43 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
https://wordpress.keystonestatecorve...m/?page_id=118
Old May 27, 2025 | 11:59 PM
talc's Avatar
talc
Default Thanks
Thanks guys. both wires definitely go through the fire wall and previously this has been working. Not sure what I'm going to do since the wiring in the engine compartment has been all nicely re-wrapped by yours truly a while back and it looks so pretty.
Old May 28, 2025 | 12:20 AM
ZIOGEO's Avatar
ZIOGEO
Why your courtesy light circuit goes into the engine compartment makes no sense. That said, you need to check if the sockets for the courtesy lights have +12V. As stated previously, the lights have +12V constant and the ground is switched.
Old May 29, 2025 | 09:26 AM
Eliredandblack's Avatar
Eliredandblack
Seems like a previous owner, probably name Bubba, used the 12 volts (for the courtesy light) to power something under the hood. Maybe a hood light, or electric choke come to mind. In any event you need to follow the wire and see where it goes. People will do all sorts of things when it comes to old cars. Do you have an aftermarket radio, ignition, or other add on items. To get the most help from Forum Members it’s imperative the you supply all the details of your car. Good Luck, electrical problems can be tricky to solve.
Old May 29, 2025 | 11:11 AM
69L88's Avatar
69L88
Old May 29, 2025 | 11:31 AM
ZIOGEO's Avatar
ZIOGEO
Leaving aside the wire going through the firewall we can still focus on the actual problem since it was working at some point.
If you have a volt meter, check to see if there is +12V on the socket (orange lead) for any one of the courtesy bulbs. Be sure you use a good ground for the black meter lead and not the bulb socket ground. On my car, the easiest bulb to get to is the driver side footwell.
To Curtesy light wiring
