Car Completely Locking Up in Reverse
Old Jun 1, 2025 | 11:50 AM
stilltrying's Avatar
stilltrying
Default Car Completely Locking Up in Reverse
Got a 1979 C3 with a four speed manual box and a positraction rear end. Rear end was grumbling for a while so I replaced the wheel bearings and a few bushes, put back on the road all seemed good for about 100 miles, then the grumbling and shuddering of the whole car at very low speeds, slipping the clutch a bit in town traffic conditions started.
Yesterday I was out and about, wanted to reverse into a parking space and the whole back of the car lifted as though, either the hand brake was on or I had hit a high kerb, neither of which had happened. I managed to drive about 40 or so miles back home without issue but then when trying to reverse at home the very same thing happened again, locked up solid so today I removed the diff, my thinking was that as there was some slack in the drive yolks something may have got damaged in the diff and it was locking up the crown wheel.
Having now removed the diff and opened it up I can't see anything that stands out as incorrect, I haven't fully cleaned it yet so will look deeper when it's cleaned up but to make the car come to an abrupt halt I was expecting to see some obvious carnage.
Anyone got any ideas what might be causing this?
Old Jun 1, 2025 | 12:32 PM
GTR1999's Avatar
GTR1999
If you have the diff out, can you spin the pinion in either direction without binding? If it's in the diff look for a broken ring gear bolt or cross shaft bolt that would lock up the diff. Should be obvious once you check it.
Old Jun 1, 2025 | 03:16 PM
stilltrying
Hi thanks for the response. Got the diff out no bolts missing all in place, no debris in the diff or housing, all oil drained out. Pinion turns easy by hand in either direction, no binding at all.
I do have a huge amount of play in the side yolks which i knew about when I did the wheel bearings.
I'm this far in so I may as well remove everything and do a rebuild, will have to do a google on how to and what parts I need.
My next worry is if it isn't the diff then it can really only be the gearbox and I'm leaning towards removing that as well while I have the car off the road.
Old Jun 1, 2025 | 04:49 PM
Fly skids up!'s Avatar
Fly skids up!
From what you are describing, (rear end lifting in reverse) something in the trailing arm assembly has gone amok. My guess would be something with the parking brake. I can't see how a problem with the differential is going to cause the car to lift its rear end in reverse.
Old Jun 1, 2025 | 05:19 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I've seen cars lock up in reverse, manual transmission.
but that's generally being in 2 gears at the same time. Which will stall the engine when you let out the clutch.
So I agree, I don't think the problem is in the transmission.
I would be looking at wheel bearings/parking brake issues.
Old Jun 1, 2025 | 06:57 PM
forman's Avatar
forman
I would lean towards the Muncie if it is stuck in 1st and reverse at the same time it will do what your saying ..if the linkage is loose or out of adjustment this will happen
Old Jun 1, 2025 | 07:23 PM
GTR1999's Avatar
GTR1999
79 would have a BW super T-10 4 speed, some had Saginaw which were weak.
Since you have the diff out you can check it and the outer axles individually. If they are free, your issue is forward as you're thinking.
The outer axle should rotate- not free wheel- without any binding, forward or reverse. You should not have any rocking pressing on the rotors at 3 & 9, there should be now endplay if you grab a wheel stud and push/pull on it.
The 79 diff's had bad axles, clutches, and ring gear bolts. The quality or replacement axles today, new or rebuilt, needs to be understood and checked no matter where you buy them. There are issues with all of them. I had a 50% rejection rate with some, others are bad design, and some may not be the same steel GM used. The diff should be built to your application. If that is just a driver, no high power, no abuse, a stock-built diff will work. A more detailed one will work better.
If you're a handy guy and have access to measuring tools, possibly machinery- depending on how you want to build it, and good hand tools you can do it at home.
Old Jun 1, 2025 | 09:41 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I too was almost positive you had a broken gear tooth or a loose ring gear bolt...but...
"Rear end lifting" clue...
I do not see how that could be transmission or diff.
The wheel bearings just got worked on. A problem is frequently in the last are a that was worked on. So check the parking brake parts.
You should have both half-shafts off already since the diff is out.
Pull the wheel and rotors and see how the new wheel bearings spin. Both directions. Look at the parking brake stuff. Spin it with rotors on and rotors off.
I agree something binding in there could use the trailing arm as leverage and try to jack up the rear of car.
Old Jun 2, 2025 | 02:02 AM
carriljc's Avatar
carriljc
stilltrying
I also thought you had gotten that lousy gearshift into 2 gears at the same time...... happened to me lotsa times. Annoying.
Old Jun 2, 2025 | 05:11 AM
stilltrying
Hi thanks for your reply, The trailing arms have just had all new bushes fitted, along with new inner and outer wheel bearings and the handbrake mechanism, I could understand the parking brake causing the rear to lift but both sides would have to be doing exactly the same thing at exactly the same moment and also be able to completely lock the rear wheels as the car will not move backwards at all when this happens, so even if the shoes were detaching I can't see how they would abruptly stop the car but the wheels are off so I will take the calipers off and check.
Old Jun 2, 2025 | 05:20 AM
stilltrying
Thanks for your reply.
All new bearings and bushes along with brake shoes etc. and as said to a previous reply both side would have to be doing exactly the same thing at exactly the same time plus I doubt that the parking brake would stop the vehicle completely dead but would "give" as in not grab instantly. When this happens it is instant dead stop. Having said that I will remove the calipers and look at the parking brake system just to check as the wheels are already off.
The gear change is a little "loose" and has been for a very long time, maybe it's got worse and I just haven't noticed, hadn't thought it could be engaging two gears at the same time. Whatever is going on it is locking up both sides of the car at the very same time as both side raise not just one side.
Old Jun 2, 2025 | 05:28 AM
stilltrying
Hi thanks, this wasn't something I had considered, the linkage is a little loose, maybe I just haven't noticed it has got worse, I've had this car for the best part of twenty years and to be perfectly honest it gets left outside in all weathers, started up driven, oil and filter changes and that is about it till something goes wrong. Did have to change the cam and followers a while back plus the carb and the rear trailing arms and bearings got done as I had loads of side to side movement at the wheels plus a bearing noise, I also noticed that the side yokes had way more movement than they should but ignored that just so I could use the car again quickly.
I'm sure the linkages need what ever bushes replacing so will take a look.
Old Jun 2, 2025 | 05:41 AM
stilltrying
I did the trailing arms a shortwhile back as I had a bearing noise and had a load of movement side to side (3-9), new bearings inner and outer along with new bushes cured that but a slow pull away would still have a vibration that was unpleasant but I could live with that, the locking up in reverse is a whole new ball game and one that really worried me as I was afraid if the rear locked up at speed going forwards I could have been in for an accident.
The diff needs a rebuild as there is a load of movement in and out, I knew this when I did the trailing arms but thought I would get the summer driving done and do a rebuild during the winter, however, now I have completely removed the diff now is the time to do it.
The outer axles do not free wheel I have to use some pressure but they are free in both directions as is the pinion, a quick look and I can see that this has been out of the car before as there is a load of blue sealant on the rear cover, however, this would have been more than twenty years ago, prior to my ownership.
I will take some photo's and post up incase anyone can see an obvious issue. I know the side yokes need work that is for sure.
Old Jun 2, 2025 | 05:51 AM
stilltrying
Thanks for your reply. I will be rechecking the brake system again, there is no side to side movement on the wheels and I'm glad of that as the car has only done about 200 miles since they were replaced and there is no bearing noise plus they turn freely in both directions.
When this happens the car completely locks up dead which I doubt the braking system is capable of and it's both sides at exactly the same time, with the force this stops the car I would expect to see contact patches inside the drum area or on the hub so not discounting anything yet but will let you know what I find inside.
Old Jun 2, 2025 | 05:58 AM
stilltrying
Originally Posted by carriljc
stilltrying
Hi thanks, this was not something I had thought about but if it is relatively common than I need to check all the linkages as a first step. When it happens it is a dead stop and raise of the rear end within lest than a foot of travel.
Someone mentioned that the engine would die as well but to be honest this has only happened very recently when I was first trying to reverse park in a space so I was slipping the clutch at the time then the car raised up and I thought I had hit a kerb so obviously dipped the clutch instantly, if I had not done so then it very well may have killed the engine. When I got home I went to reverse but was waiting for it to happen, which it did, so again dipped the clutch instantly so I have no idea if it would have killed the engine. It's too late now to check as it is all apart.
Old Jun 2, 2025 | 06:42 AM
bashcraft's Avatar
bashcraft
Check the parking brake. It has to be something at the hubs, nothing else will cause the rear to lift.
Old Jun 2, 2025 | 10:10 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Clue... complete stop within less than a foot of travel.
Well that clue sounds like the trans is in two gears at once, reverse plus another. It is kinda common. That would be a shifter issue.
You already ruled out a broken diff gear tooth. So now you have two things left to check, shifter and park brake.
You'll get there.
Interpreting people's clues can get very difficult and even entertaining at times. But we are here to help.
Does anyone remember the joke about the mechanic who could not duplicate the older lady's stalling problem?
She said: "I told you, it only happens when I get ice cream!"
LOL
To Car Completely Locking Up in Reverse
Old Jun 2, 2025 | 11:05 AM
Mark60's Avatar
Mark60
I would check all your Ujoints for play, it could be the rear one at the different or a combination of more than one.
Old Jun 2, 2025 | 12:16 PM
carriljc's Avatar
carriljc
stilltrying
well..... it's easy enough to check if you already have it up in the air. If not, then jack the driver side of the car up, jack-stand it, and crawl under there and ensure the linkage is not in 2 gears at the same time.
And, YES, it tends to happen when you go into reverse, come out of it, and slap into 1st and then your car doesn't move..... if you're LUCKY then you're able to wiggle it back into Neutral and out of both gears..... then select the gear you wish and it moves.
If such is the case, and pending the adjustment/tightening/refurbishing of the shifter just be real gentle and no quick shifting......
Old Jun 2, 2025 | 12:18 PM
carriljc's Avatar
carriljc
oh.... and another pointer.....
I have learned to come here and ask before I get carried away fixing things because I assumed something ...... lots of folks here with lots of experience. They've straightened me out lots of times.
I am assuming things from your initial description....but I *think* you put it into Reverse, then went to drive forward and it wouldn't move...... I reckon that you then wiggled the shifter around until you were to get going again? Not sure? So I'm guessing..... that's what would happen to mine..... EXCEPT I was never lucky enough to wiggle it out of lockup and had to crawl under to put the shifter back into neutral.
