Dot 5.1 Brake Fluid
Old Jun 3, 2025 | 08:46 PM
Miccar's Avatar
Miccar
Default Dot 5.1 Brake Fluid
I am replacing my leaking front brake calipers with new CSSB SS sleeved o'ring calipers. I am also going to have the fluid flushed and the brakes bled. I know there has been a lot said about not using 5.0 dot brake fluid, but does anyone think it would be a good idea to use a good 5.1 dot fluid? This fluid was developed to fix some of the inherent weaknesses in dot 5 fluid and still be useable in systems that can't use silicon fluid. Anyone think using 5.1 would be a good idea?
Old Jun 4, 2025 | 05:49 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I think changing those cheap Orings out and running silicone DOT 5 is a great idea.
DOT 5.1 is just high grade DOT4
Old Jun 4, 2025 | 09:38 AM
drwet's Avatar
drwet
DOT 5.1 is high performance (high temp) regular (glycol based) brake fluid. It is the best choice for our application.
Silicone can work, but you need to flush the whole system of the existing fluid if you want to switch to it. The bigger problem is a lot of components aren't compatible with silicone these days. Apparently the composition of silicone fluid changed some years ago and started eating seals and o-rings. Many suppliers of calipers will not honor the warranty if you use silicone.
The only advantage to silicone is it is not hygroscopic. In addition to the compatibility problem, it is also slightly compressible, and therefore not as effective as a hydraulic (brake) fluid.
FWIW I am running silicone (DOT5) in my car, but only because the previous owner went to the trouble of installing it. If I had my druthers, I would be running DOT5.1 and flush it every five or ten years.
Old Jun 4, 2025 | 09:59 AM
Bikespace's Avatar
Bikespace
I think a choice was made to use different O-Rings, which are not compatible with silicone fluid, hence the warning label that comes with CSSB Inc brake kits. But their kits work great! I use their "high-heat" kits, which are likely Viton O-rings likely Silicone.
Anyway, 5.1 is fine. I started using Bosch ESI6-32N, because the old brake fluid naming convention was too simple, and it's a bit cheaper than the DOT 4 I had been using.
EDIT: These look like the CSSB kits I used. They are sold as Silicone high heat O-ring brake kits. I guess that's why they are incompatible with DOT 5.0 (silicone) brake fluid.
https://www.corvettecentral.com/c3-6...liper-o-192343
Old Jun 4, 2025 | 01:42 PM
Miccar's Avatar
Miccar
Thank you.
Old Jun 4, 2025 | 09:14 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The fluid has not changed composition; the problem stems from rebuilders not using EPDM rubber seals and instead using inferior products that historically were not used for brake parts. EPDM has been the standard seal material for well over a half-century and performs well in both ethylene-glycol and silicone fluids. Why they are using something different is likely about purchasing the cheapest seals they can get away with.
If you really want to go back to E-G fluids, just flush out the silicone. The two fluids don't interact so won't form gel or sludge or anything of the sort. Buy a quantity of the cheapest DOT 3 you can find and flush with that, then put in whatever 3, 4, or 5.1 you desire.
Old Jun 4, 2025 | 10:11 PM
4-vettes's Avatar
4-vettes
Old Jun 6, 2025 | 07:29 PM
John Ulrich's Avatar
John Ulrich
Any brand names or vendors come to mind who sell EPDM caliper seals
Old Jun 6, 2025 | 07:42 PM
Way's Avatar
Way
Old Jun 6, 2025 | 10:40 PM
barkingrats
Raybestos Element 3 seal kits use EPDM: WK452 (front), WK453 (rear)
Old Jun 7, 2025 | 09:17 AM
theandies's Avatar
theandies
Been running DOT5 for years without problems. Years ago I replaced all my calipers with the o-ring style and nowhere in the instructions said to not use DOT5 and I asked the vendor (Van Steel I think, sucks getting old) if the o-rings were good with DOT 5 and the answer was yes. To this day my stock 4-piston caliper Vette stops better than any of my modern vehicles.
Old Jun 7, 2025 | 11:31 AM
barkingrats
That's the thing! You can easily get EPDM o-rings that will fit and work fine with any fluid a customer chooses. I think the rebuilders are just cheaping out.
To Dot 5.1 Brake Fluid
