Snubber Bushing -Rubber or Polyurethane
Old Jun 9, 2025 | 06:38 PM
theandies's Avatar
theandies
I went with poly at this location just because it's a bitch to get to and poly will last longer than rubber. I did go rubber on my suspension rebuild as I didn't want to hassle with installing poly bushing which are not as forgiving as rubber.
Old Jun 9, 2025 | 09:26 PM
SteveG75's Avatar
SteveG75
Originally Posted by 3X2
I did it in the late 70's along with his crossmember biscuits and heim end camber bars.
I have had the biscuits for a while and just did the Van Steel delrin bushings. The Van Steel pinion snubber disintegrated when torqued to their spec of 70 ft lb. It has a delrin biscuit. I reinstalled the poly for now.
https://www.corvetteforum.com/forums...ntegrated.html
Old Jun 9, 2025 | 09:31 PM
Chris Hewitt's Avatar
Chris Hewitt
Another vote for metal disk.
Old Jun 10, 2025 | 03:29 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Ive got poly and its a little thicker than it needs to be. No squeaks or cracks and it has seen plenty of torque to destroy it and it hasnt soooooo.....it also doesnt squeak as far as I can tell
Old Jun 10, 2025 | 05:24 PM
Brown Bandit's Avatar
Brown Bandit
Found bushings on Zip Corvette website. Says they can get it to me in a reasonable time. Have never dealt with this company before. Is this a legitimate company? Reason i ask is cause everyone else's shipment date is 2 to 3 weeks out. Zip can ship it out in 2 days.
Old Jun 10, 2025 | 07:32 PM
Bikespace's Avatar
Bikespace
Zip Corvette is 100% legit. I order from them all the time, and have been there in person a few times.
Check for sales. You can probably get free shipping with a $100- order, or something like that.
Old Jun 11, 2025 | 10:47 AM
theandies's Avatar
theandies
Zip is a great parts supplier for Corvettes. Been to their location in Richmond, Va a few times. Real Corvette people. I use them all the time as I'm just an hour or so drive and shipping is super quick because I'm so close.
Old Jun 11, 2025 | 10:49 AM
theandies's Avatar
theandies
Originally Posted by 427Hotrod
I installed Energy Suspension poly all over my car 25+ years ago. No squeaks and no wear.
But I did install a poly pinion mount bushing and it was great. Now I tend to beat on mine a little harder than most.....but mine eventually punched a hole through the frame mount just like you took a hole-punch and cut a perfectly clean circle of metal out. I made a new mount of much thicker steel and put back together with a poly and it's been fine ever since.
JIM
Come on Jim, you know you baby your car. I don't believe you.......
