AC clutch slipping / screeching
Old Jun 27, 2025 | 03:53 PM
  #41
Fly skids up!'s Avatar
Fly skids up!
Sounds like some blockage on the high side. What's the high side pressure right before the engine stalls?
Old Jun 27, 2025 | 04:40 PM
  #42
MelWff's Avatar
MelWff
If you read through the posts you will learn he states he doesn't have a high pressure port.
Old Jun 27, 2025 | 05:58 PM
  #43
Fly skids up!
I stopped following this thread after my first post and said my peace and that fell deaf ears. I only started to follow this thread again after the OP posted the video and reiterated that the belt was slipping. So I didn't read that part.
Anyway that's the OS's first problem. Not having a high or low port in a A/C system is like car without a gas cap. It's a standard item.
MacTrader, if you're reading this check your A/C mounting again. I saw that compressor shift a little when it kicked in.
Old Jun 27, 2025 | 07:11 PM
  #44
carriljc's Avatar
carriljc
That is all good to find out.
If they let you return that thing then consider getting your money back and buying a modern sanden......
Originally Posted by MacTrader
I sprayed the belt with belt dressing. ( Sticky gooey stuff ). The belt must have been slipping because now it just stalls the engine from a 1000 rpm fast idle. Just too much drag from the compressor.
Seems pretty clear now what I have to do to fix this.
Thanks Everyone
