still blowing bubbles
Old Jun 30, 2025 | 12:40 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I feel like you may need some in-person guidance to help sort this out. Where in the world is the car located - nothing detailed, just need a general idea so someone in that area could offer their experience.
Old Jun 30, 2025 | 01:48 PM
sunflower 1972's Avatar
sunflower 1972
Originally Posted by signify
How do i reset brake lite,i stabbed pedal while vehicle vvas running nothing.brake pedal goes directly to floor
I posted resetting info for you way back on June 21, https://www.corvetteforum.com/forums...ing-valve.html
Old Jul 1, 2025 | 10:47 AM
signify's Avatar
signify
I found it! How do you reset by bleeding with my motive? It is in a hard location for acess
Old Jul 1, 2025 | 12:19 PM
barkingrats
If it is indeed "tripped", your dash brake light should be on continuously...
To reset it, one technique is to press the pedal really hard and fast a few times. This may cause the inner piston to recenter. (Try this first.)
The second method is to remove the fitting where the warning wire is attached. A very small pick or screwdriver inserted in the hole can push the piston back to center.
Old Jul 1, 2025 | 12:20 PM
Joey_SS's Avatar
Joey_SS
I'd rough bleed the system. Fill the master cylinder up and clamp your Motive down. Get a hang for it. Once you're competent.... then remove the master cylinder and bench bleed it. I never had to reset my proportioning valve with a Motive. If it acts up, stab the pedal a few times. Bleed the system again until all the air is gone. Obviously dont allow the master cylinde= to run dry.... then you gotta bench bleed the master cylinder again
