clutch fan numbers
Old Jul 11, 2025 | 09:32 PM
Bills17n72's Avatar
Bills17n72
Default clutch fan numbers
i have this clutch fan from a 69 , the numbers on the front can anyone tell me what they mean , or where do i look on the fan to give me information? thanks Bill
Old Jul 12, 2025 | 08:25 AM
7T1vette's Avatar
7T1vette
They are Eaton numbers for identification and or production processing. You would need an Eaton cross-reference document to define what GM part numbers where that unit was used.
Someone in NCRS may have specific knowledge of that thermo unit.
The 1969 AIM will provide the GM part number for that thermo unit (engine section A3). For 1971 base engine, that part is P/N 3916139. IDK if that is the same unit used for 1969 or not.
Old Jul 12, 2025 | 05:57 PM
Bills17n72's Avatar
Bills17n72
thank you 7t1vette!!
Old Jul 12, 2025 | 07:30 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Bill,
The Eaton date codes are something that I’m not super familiar with, but I can tell you that the format in the 1968-1972 range typically has a single letter code for the month, a one or two digit number for the day, and a single letter code for the year. I think that the month codes run consecutively beginning with A… And while I can’t tell you all of the year codes, I do know that 1969 is J. Someone like Dan Kirkconnell or Fred Oliva could probably recite this info in their sleep… I would reach out to one of those guys and you’ll probably get your answer.
For what it’s worth, that style of fan clutch was used was used only on base engine cars and some early L-88s. It was also installed (incorrectly) on the first group of 1969 L-88M-40 cars as was part of a list of items replaced under recall.
Regards,
Stan Falenski
Old Jul 12, 2025 | 08:56 PM
Bills17n72's Avatar
Bills17n72
thanks stan , I will try to get ahold of them guys , oh I see you are one of the 25 yr guys also!! ill
Old Jul 13, 2025 | 10:26 AM
interpon's Avatar
interpon
My fan clutch education
https://www.corvetteforum.com/forums...re-79-l82.html
Old Jul 13, 2025 | 03:20 PM
Bills17n72's Avatar
Bills17n72
well thank you interpon , but that illustration is way over my head , I dont have a clue of where to look where my clutch fan would be on that ,I was told it is from a 69 corvette, any help? thanks Bill
Old Jul 14, 2025 | 05:30 PM
interpon's Avatar
interpon
hmmmm. looks like no markings? eaton shows after? are there numbers on the edge of fins around?
Old Jul 14, 2025 | 10:24 PM
Bills17n72's Avatar
Bills17n72
interpon , I did find two numbers on one of the fan blade it is the number 27 that's all
To clutch fan numbers
