OEM brand electral componets
Old Jul 14, 2025 | 05:38 PM
bmac57's Avatar
bmac57
Default OEM brand electral componets
Does anyone know of a better-quality source for remanufactured relays and such than OEM brand? I have not had good luck with OEM.
Old Jul 14, 2025 | 10:01 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The two brands that seem to have higher reliability over other aftermarket brands are: Standard Motor Products (SMP) and Echlin (NAPA's brand),
Old Jul 14, 2025 | 10:10 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I like Bosch relays. And SMP Products. Ignition I prefer Performance distributor or DUI.
Old Jul 15, 2025 | 08:40 AM
ctmccloskey's Avatar
ctmccloskey
I am also a big believer in BOSCH relays and components. If I add a new relay to my car it will always be a new Bosch relay as I have had awesome experience with them. Echlin is always a good backup for me. I have places where I installed a Bosch relay 25 plus years ago and they are still working like new. I bought a box that had 10-15 Bosch 40 amp/12 Volt relays and I still find uses for them.
For an important relay that is hard to change then I would use DeOxIt and clean the terminals inside the relay. It is fairly easy to clean the contacts and then treat them to make them last longer. I fixed various relays by simply cleaning the parts and ensuring good connections inside the box.
Old Jul 15, 2025 | 11:27 AM
7T1vette's Avatar
7T1vette
GM parts are nearly ALL foreign made (mostly Mexico and China) and put in BOXES which are "Made in USA". Only as a last resort would I ever purchase them.
Old Jul 15, 2025 | 05:37 PM
Rebelyell's Avatar
Rebelyell
FWIW
Echlin is also an SMP brand, as is Blue Streak; and Accel grew out of Echlin's desire for a hi-po ignition line.
And SMP is a Tier 1 supplier to traditional OEMs.
In addition to traditional OEM, there's also a separate trade name OEM; also an SMP brand.
https://www.oemautoparts.net/en
Things change; count on it.
Old Jul 15, 2025 | 07:51 PM
bmac57's Avatar
bmac57
Thanks for all the good advice, I ordered a SMP relay from Rock Auto. This is the hi-speed blower motor relay that sits on the side of the AC box under the hood. They had 2 SMP relays listed for a '69 Corvette I got the one for $32.79 because it had 4 terminals like the original AC relay. The other one had 5 terminals and was about $10 cheaper. I'm hoping the extra $ means it has better quality contacts. I went through 2 new OEM relays; each lasted for less than an hour of operation before failing.
Old Jul 15, 2025 | 10:05 PM
Rebelyell's Avatar
Rebelyell
Dunno which particular parts you looked at, BUT for future reference:
SMP often offers two nearly identical part numbers for approximately same part.
Some will have a "T" suffix. I avoid those. They're usually somewhat cheaper but also have a lesser warranty.
They're marketed with the commercial garage/shop in mind where the lowest cost is paramount; and little else.
No doubt I like SMP, but just sayin'
Old Jul 20, 2025 | 05:46 PM
sphil's Avatar
sphil
“Box” is made in the USA😂
Old Oct 27, 2025 | 10:26 AM
bmac57's Avatar
bmac57
Just wanted to update y'all on my blower relay. I installed the SMP relay in July and have driven the car quite a bit this summer always with the AC on high. The SMP relay has been doing its job. Thanks again for the tip.
Old Oct 27, 2025 | 01:08 PM
Rebelyell's Avatar
Rebelyell
FYI: SMP Owns OEM Brand.
"SMP has four operational segments. Vehicle Control brands include Standard, Blue Streak, Echlin, BWD, GP Sorenson, Belden, OEM, and Pollak".
Suggest Step up to & choose parts labelled/boxed Standard and/or Blue StreakGood that you've already done so and finding joy w/ SMP-branded relay !
Suggest do Not choose Standard brand parts having a "T" suffix; those are bargain-priced And intended for shops requiring better profit margin And they have lesser warranty. Other brands may ALSO have a similar 2 or 3-tiered price v. value scheme.
Old Oct 27, 2025 | 01:16 PM
1Hotrodz's Avatar
1Hotrodz
It's quite possible that you are burning up relays due to the blower motor drawing excessive amperage due to age related problems, like a dirty commutator. Check your current draw on the blower motor.
Old Oct 27, 2025 | 01:36 PM
Rebelyell's Avatar
Rebelyell
^^^THIS^^^
Or, to include a binding bearing/bush needing lube or R&R.
To OEM brand electral componets
