Help .. tachometer cable broken
Old Jul 18, 2025 | 02:20 PM
khaid2436's Avatar
khaid2436
Default Help .. tachometer cable broken
Hi everyone..
Where does the tachometer cable connect on a 1973 Corvette?
Because I found it cut off and the tachometer is not working and I don't know where to connect it
I hope you can help me with the explanation with pictures so that I can understand the method perfectly.
thanks..
Old Jul 18, 2025 | 02:33 PM
alt66's Avatar
alt66
On the distributor on the shaft right under the cap might go straight on the threaded connecter or the connecter might have a right angle adapter on it,
Old Jul 18, 2025 | 03:28 PM
khaid2436's Avatar
khaid2436
If you mean this hole in the picture, I searched for it but did not find it. My distributor does not have it.
Is there another way or place to connect the cable?
Old Jul 18, 2025 | 04:02 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome
The distributor in the picture is mechanical. Post a photo of yours, and some will determine if yours is an electrical distributor with wires, not a screw on terminal..
Old Jul 18, 2025 | 04:29 PM
khaid2436's Avatar
khaid2436
I don't have a picture of it now, but it's similar to this one. My Corvette model is 1973, but this type in the picture says 75-80. In this case, what does it mean? Has it been changed? And how do I connect the cable?
Old Jul 18, 2025 | 05:22 PM
alt66's Avatar
alt66
If yours is a 73 somebody has switched out the distributor.
Old Jul 18, 2025 | 05:30 PM
khaid2436's Avatar
khaid2436
Do I need to change the distributor?
Or is there a part in the distributor that can be changed without changing the distributor to connect the cable?
Old Jul 18, 2025 | 05:38 PM
9forty's Avatar
9forty
It looks like they removed the old "points" distributor with the mechanical tach plug in provisions and replaced it with an electric "HEI' distributor... you'll have to convert your tach over to an electrical tach and plug it in to the distributor you now have in place.
Old Jul 18, 2025 | 05:44 PM
9forty's Avatar
9forty
Old Jul 18, 2025 | 05:47 PM
9forty's Avatar
9forty
The Tachs are also available at Corvette Central already converted to electric if you wanted to go that route.
sphil's Avatar
sphil
Did you just purchase the car and realized the tach didn’t work, or was it working and suddenly stopped?
Old Jul 18, 2025 | 06:32 PM
khaid2436's Avatar
khaid2436
Originally Posted by 9forty
The Tach's are also available at Corvette Central already converted to electric if you wanted to go that route.
Can you give me the link?
Old Jul 18, 2025 | 06:33 PM
khaid2436's Avatar
khaid2436
I bought it in this condition and it wasn't working.
Old Jul 18, 2025 | 06:36 PM
9forty's Avatar
9forty
1968-1982 C3 Tachometers & Cables | Corvette Central
Old Jul 18, 2025 | 06:44 PM
khaid2436's Avatar
khaid2436
Is there a cheaper solution instead of changing the Gauge
Old Jul 18, 2025 | 06:47 PM
9forty's Avatar
9forty
If there is, I am unaware of it. Might need to hear from the more seasoned veterans on this forum.
Old Jul 18, 2025 | 09:26 PM
Haggisbash's Avatar
Haggisbash
You can get a cheapish HEI distributor similar to the one you already have except it also has the tachometer drive. However, if you want to go this way first I would check the tachometer is working by spinning the cable by hand. If the tachometer isn't working you might as well keep the distributor you have and change the tachometer to an electric one. I fitted one of the China tachometer drive distributors but upgraded the coil and internal module. Done several thousand miles so far with no issues.
To Help .. tachometer cable broken
Old Jul 19, 2025 | 05:05 AM
khaid2436's Avatar
khaid2436
Is it better to change the distributor or change the tachometer to electric ?
Because they cost almost the same.
Old Jul 19, 2025 | 05:57 AM
Haggisbash's Avatar
Haggisbash
Is your tach working? Its easier to swap out the dist than the tach as long as you know or prepared to read up on doing the install.
Old Jul 19, 2025 | 06:09 AM
khaid2436's Avatar
khaid2436
I’m thinking about switching to electronic ’cause after doing some research, I found out the cable always breaks. That’s probably why mine’s messed up.
Yeah, just like you said — it’s gonna take more work since I’ll need to take the gauge out.
