Best brake booster solution
Old Aug 7, 2025 | 11:06 PM
JakeLucas's Avatar
JakeLucas
Default Best brake booster solution
Reference thread. https://www.corvetteforum.com/forums...thread-10.html
My son went with the full Ridetech suspension kit with this brake kit.
His new bored 454’s big cam produces low vacuum. So the brakes work but are not working as well as they should. We’re thinking about going with a hydro-booster. The two that we’ve found to be the best are Hydratech and Hydrastop.
https://www.hydratechbraking.com/C3Corvette.html
https://classicperform.com/cpp_hydrastop
Some have suggested going with an electronic assisted vacuum booster. CCP has a better site but of course that doesn’t mean that they have a better product. The vacuum booster would be cheaper but I’m not sure how well they work. Any insights or suggestions would be welcome.
Old Aug 8, 2025 | 09:17 AM
pspicci's Avatar
pspicci
How low is your engine vacuum? I have about 9" in gear idling and top out at 19" cruising and my power brakes work fine.
Pat
Old Aug 8, 2025 | 07:01 PM
JakeLucas's Avatar
JakeLucas
Not sure. My mechanic buddy just said that my brakes are not working well due to low vacuum.
Old Aug 8, 2025 | 07:07 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
He probably needs to bleed them properly.
Old Aug 8, 2025 | 08:43 PM
JakeLucas's Avatar
JakeLucas
Interesting point. I asked him.
Old Aug 8, 2025 | 09:04 PM
JakeLucas's Avatar
JakeLucas
He’s not the one that installed them-but I’ll look into it. Thanks.
Old Aug 9, 2025 | 10:11 PM
JakeLucas's Avatar
JakeLucas
He said it’s lack of vacuum.
Any one have any opinions about brake boosters?
Old Aug 10, 2025 | 12:39 AM
Rebelyell's Avatar
Rebelyell
IMO, a simple 'lack of vacuum' ain't enough info. Perhaps he should inform you with vacuum numbers he measured; again, measured ?
FWIW, if yours is a '74, it has Lotsa vacuum-operated components and Lotsa potential vacuum leaks.
Old Aug 10, 2025 | 09:50 AM
HeadsU.P.'s Avatar
HeadsU.P.
Yes.
Leave them alone.
Seldom do boosters go bad.
Often a replacement will not fit the "finicky" C3.
Often the booster is cussed at trying to remove nut #4.
Seldom does a new the booster mate-up perfectly with the GM master cyl.
Often it's the check valve failed and not the booster itself.
So, back to your mechanics analysts:
Does the brake pedal go to the floor while engine is running or off.
Old Aug 10, 2025 | 11:31 AM
Corey_68's Avatar
Corey_68
I ran a Tuff Stuff mini booster with a 12.1 306* duration solid cam in my 468, never had vacuum issues.
Need to ask the mechanic exactly "how low" is the vacuum.
Old Aug 10, 2025 | 12:26 PM
OldCarBum's Avatar
OldCarBum
My 496 had 10” at idle on the dyno.
Most booster manufacturers will say their boosters require 15” or more to function properly.
I ended up converting to manual brakes.
I got the same responses in a thread I posted about low vacuum.
Members would say their boosters worked fine with 9”-11” of vacuum.
I called the manufacturers back and their statements were un changing.
Many members run manual brakes because it’s how their car left the factory.
I would ask your mechanic to get a vacuum gauge and see exactly what vacuum the engine is pulling, then decide if you want manual brakes, install a new booster, leave in the old booster or maybe install an electric vacuum pump.
Old Aug 10, 2025 | 04:00 PM
carriljc's Avatar
carriljc
JakeLucas
If you really have vacuum issues you could go this way: https://corvettec3.ca/hydro.htm
Old Aug 10, 2025 | 04:29 PM
71 Vert LS1's Avatar
71 Vert LS1
On my 66 Mustang project I had a good sized cam in the 306 SBF. I went with a hydro boost from Hydratech. Worked perfect. The brakes could put your nose up against the windshield if needed. But was easy modulate.
Pic.
Old Aug 10, 2025 | 09:15 PM
TKX 5-SPEED C3
Try to bleed the brakes properly and also get the actual vacuum readings from your mechanic.
Old Aug 11, 2025 | 08:59 AM
Dream Car C3's Avatar
Dream Car C3
I used the same Tuff Stuff 2222NA Universal Power Brake Booster, 7 Inch Dual Diaphragm on my Ford 390 ....Call them with your Vacuum numbers and get an expert opinion. Made in the USA
The 7 inch diameter was critical in that application, along with low vacuum....don't remember what it was...and yes check all your vacuum lines. Too many to count.
Old Aug 13, 2025 | 07:46 PM
SteveG75's Avatar
SteveG75
Agreed.
SteveG75's Avatar
SteveG75
He needs to bleed them again. The D-8 calipers have a known problem with the bleeder screw location on the rear calipers. They need to be unbolted and rotated so that the bleeder screw is at the top. If you don't do this, you will have soft brakes no matter what.
Read this thread for more info.
https://www.corvetteforum.com/forums...take-note.html
To Best brake booster solution
Old Oct 10, 2025 | 08:38 PM
JakeLucas's Avatar
JakeLucas
We decided to go with this. It gets great reviews. My buddy that owns a shop just put one on his dad’s truck. He said that it’s working great. Anyone else use one of these.? Way cheaper than the hydro-booster in regard to both parts and installation. We’ll see how it goes.
https://www.studiohotrods.com/product-page/boostmaster
Old Oct 10, 2025 | 11:54 PM
KENS80V's Avatar
KENS80V
First thing I would recommend is to remove and cap the vacuum lines feeding the headlights and HVAC system. They are notorious for leaking on older cars. Then measure the vacuum. If it still has not improved much..... I would then think about adding a vacuum reservoir and/or vacuum pump. Lots of YouTube videos on sourcing a OEM quality pump from modern cars. Most of the OEM vacuum pumps are made by Hella. They can be bought new for about $200 or used for half that.
Old Oct 11, 2025 | 11:39 AM
JakeLucas's Avatar
JakeLucas
Thanks. Solid advice. No HVAC. Had to bypass the heater, bad core. Luckily we don’t need it too much in San Diego.
The vacuum lines were new when we bought it and they worked well. The big cam on the new 454 just is not making enough vacuum.
