69 Tach Needle Replacement
Old Sep 5, 2025 | 06:02 AM
KJLive's Avatar
KJLive
Default 69 Tach Needle Replacement
I am going to apologize up front for my ignorance. I am far from being a mechanic! The needle on the tach in my 69 corvette snapped. How difficult is it to remove and replace the needle? Any recommendations of on line videos that I can watch to understand the process? Also, where is the best place to purchase a replacement needle? Any insight would be appreciated. Thanks in advance for your help.
Old Sep 5, 2025 | 08:57 AM
pspicci's Avatar
pspicci
Most of the corvette vendors would have the needle. you need to pull the driver side dash out to access the tach. if you have basic mechanical ability you can do it just take your time. you need to disconnect the tach and speedo cable then pull the dash forward a little then disconnect all the bulbs and headlight switch from the back before you remove it. also unbolt the the 2 bolts that hold up the steering column and let it hang down a little to make it easier to pull the dash forward.
Pat
Old Sep 6, 2025 | 08:18 AM
KJLive's Avatar
KJLive
Thank you very much for your information! It doesn't sound as bad as I expected.
Old Sep 6, 2025 | 12:11 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The needle itself just presses on to the post. You should be able to remove it by pulling it away with your fingers around the needle hub. Resist using a tool to pry it off as the metal of the gauge face is thin and easily marked.
Old Sep 7, 2025 | 06:51 AM
KJLive's Avatar
KJLive
Great info to know! Thank you!
Old Sep 7, 2025 | 07:41 AM
69ttop502's Avatar
69ttop502
When you drop the steering column down, prop it up or tie it up with something as you don't want to let it hang under its own weight.
Old Sep 7, 2025 | 02:58 PM
KJLive's Avatar
KJLive
Thank you for sharing! Sounds like an important detail.
Old Sep 11, 2025 | 08:57 AM
nw2571's Avatar
nw2571
My speedo needle snapped a week or so ago. Is this common for these cars? It seemed like a total fluke failure in my mind.
Luckily for me speed ~= tach x2
Old Sep 11, 2025 | 09:18 AM
pspicci's Avatar
pspicci
You can download a free speedometer app to your cell phone and use that until you fix your needle
Pat
Old Sep 11, 2025 | 09:39 AM
barkingrats
No, I wouldn't say it's common, but does happen. My '72's tach needle dropped the long arm to the bottom of the gauge a few years ago. I think they just experience metal fatigue from the inertia.
I agree with pspicci: the apps are free and pretty darned accurate. Neither of my Corvette speedos are true when at speeds above 45mph.
Old Sep 11, 2025 | 03:12 PM
Rebelyell's Avatar
Rebelyell
Speedo and tach and other gages calibration-repair-restoration; the pros knows.
D and M Restoration
Greenville SC USA
https://dandmrestoration.com/
Old Sep 11, 2025 | 03:16 PM
litevette's Avatar
litevette
One word of caution… In case you get in there and decide to clean the face of it. Do not touch any of the numbers or lines on the face of the speedo, tach or other gauges. They will smear and smudge very easily. If tempted to clean, just blow them with compressed air or a can of keyboard dusting air. You can go around the black areas with a q-tip carefully, just make sure (as previously stated) not to rub the numbers or lines.
Old Sep 12, 2025 | 05:29 AM
KJLive's Avatar
KJLive
Wow! Thank you.
Old Sep 12, 2025 | 12:14 PM
HCK's Avatar
HCK
Also, if you have not started yet, be gentle with the dash it is old and can crack easily.
Old Sep 13, 2025 | 12:58 PM
KJLive's Avatar
KJLive
Goof point! Thank you!
To 69 Tach Needle Replacement
