Tach
Old Sep 8, 2025 | 01:24 PM
Jerry1978's Avatar
Jerry1978
Default Tach
Gents,
My 1978 tach sits on the needle until I get up over I would guess about 3500 rpms then it runs up to redline and drifts back down. Any ideas what is going on there?
Old Sep 8, 2025 | 04:15 PM
sunflower 1972's Avatar
sunflower 1972
https://www.google.com/search?q=1978...h=503&dpr=1.67
Old Sep 8, 2025 | 04:21 PM
BKarol's Avatar
BKarol
First thing to do is eliminate the tach filter. Remove both ends and put the tach connection into the distributor. No need for any interference. If still the same then need to look into the tach circuit board. Lots of links in the above post.
Old Sep 8, 2025 | 04:53 PM
interpon's Avatar
interpon
and after filter.. i found a board here that works.. and tried a few.. skip to post 140
https://www.corvetteforum.com/forums...uestion-7.html
Old Sep 8, 2025 | 06:53 PM
HeadsU.P.'s Avatar
HeadsU.P.
The tach filter does not give interference to the tach dial but rather prevents interference from HEI ignition (spikes)
And it protects the tach's sensitive circuit board from damage.
If someone does not need the filter for some reason, good for you, lucky.
But to the rest of us, do you want to take a chance the absence of the filter will not fry a circuit?
Old Sep 8, 2025 | 07:31 PM
Rebelyell's Avatar
Rebelyell
send it !
D and M Restoration
tach, gage repair/resto
https://dandmrestoration.com/
To Tach
