Feedback needed on engine block numbers
Old Oct 1, 2025 | 09:32 PM
NormB1's Avatar
NormB1
Default Feedback needed on engine block numbers
Supposed to be an original 454, has a 4 speed manual, and A pilar VIN is matching, but last two digits on engine are not as deep as the rest.
Opinions?
Old Oct 1, 2025 | 09:56 PM
69L88's Avatar
69L88
CPH code was used in 1971 and 1972.
Not worried about the stamping. Can you look at the aft shelf of the block and get the casting number and casting date?
Old Oct 1, 2025 | 10:14 PM
NormB1's Avatar
NormB1
Thanks, and sorry should have said it is a 1971 convertible.
I was not able to look at the rear of the block numbers.
Old Oct 1, 2025 | 10:29 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I'm far from a stamp expert but will say the VIN looks OK to me. The number shapes all seem to be typical Chevrolet - even the three variations for the 1 - and are all aligned. You can see that the gang holder is struck really heavily on the left and diminishes you read to the right -- it was likely not placed against the pad with equal pressure. You also have character blocks with varying heights, so some numbers leave a lighter impression than others.
Old Oct 2, 2025 | 01:57 PM
Alan 71's Avatar
Alan 71
Hello,
The vin derivative was stamped on the transmission case at the same time as the engine pad... what does that stamp look like?
Typically the same person loaded the holder and used it for the engine and transmission.So typically the same idiosyncrasies appear in both places.
Regards....
Old Oct 4, 2025 | 06:50 PM
NormB1's Avatar
NormB1
Originally Posted by Alan 71
Hello,
Regards....
Thanks, good to know, but I was not able to look at the transmission stamp when I looked at the car.
To Feedback needed on engine block numbers
