1969 headrest
Old Oct 4, 2025 | 02:07 PM
jtp2805's Avatar
jtp2805
7th Gear
Default 1969 headrest
My passenger headrest was installed backwards by previous owner and I cannot get it out , I removed the rear panel and do not see access to the headrest mechanism
Old Oct 5, 2025 | 10:18 AM
69L88's Avatar
69L88
Viewed as if standing behind the seat, pull the headrest out until you hit the stop, tilt the headrest to the right, it will only move a degree or two. This will allow a tab at the right bottom of the chrome shaft to drop into the rail that the chrome shaft slides in. You're compressing a piece of spring steel in the rail that pushes the chrome shaft to the right that keeps the tab at the bottom right of the chrome shaft from dropping.
