Rebuilding the center gauge console and one of the warning lights has 3 contact points. The upper left one, but none of the bulb holders I have have 3 contacts.
I can see on the original that there was three contacts...
Anyone know where to get that bulb holder none of mine have three contacts?
I don't think the bulb has three contacts just the connector so maybe the low fuel is part of something in the bulb holder. For sure there are three contacts on that part of the circuit.
Your 82 I believe utilizes 1 more socket not used on a 77...
PCB with 77 circuits & wire colors...
This is a huge help because I'm putting in LED's that have a + and - side so I need to know which ones are negative so I can test the LED orientation out. I'm wondering if when you turn the ignition on does the fuel low come on until it's running? I bet 11 and 9 won't turn on the fuel low light without 10 being some voltage.
JT
My experience, the low fuel light only comes on if no signal from sender or at about 3 gallons of fuel remaining, but my 77 has a smaller fuel tank...
Does anyone have an idea how to test the low fuel module out of the car? I have LED lights that I must verify the polarity. I tried putting 12v on pins 9 and 11 but I'm guessing the low fuel module needs something on all three pins to light up. I might just stick an incandescent light in that one for now. I just need to get on with putting the car back together.
