Need Torque Spec: Bolt / Screw
Old Jan 4, 2026 | 06:51 PM
jigoe007's Avatar
jigoe007
Default Need Torque Spec: Bolt / Screw
Guys:
I can't find the torque spec for this bolt / screw. It's located down low in the right hand rear tire well. I thought it would be shown in the rear differential section of the factory assembly manual.
Old Jan 4, 2026 | 07:57 PM
lars's Avatar
lars
AIM states 45-55 ft-lbs.
Old Jan 4, 2026 | 08:21 PM
jigoe007's Avatar
jigoe007
Thanks y'all!
Old Jan 4, 2026 | 09:01 PM
GTR1999's Avatar
GTR1999
Weight on the ground
Old Jan 4, 2026 | 11:46 PM
lars's Avatar
lars
Old Jan 5, 2026 | 04:16 PM
mapman's Avatar
mapman
jigoe007
Purpose of "Weight on the ground" is to put trailing arm at ride height.
You can approximate trailing arm position of "weight on the ground" by placing a 9/16" socket (half-inch drive) set between trailing arm and frame pocket's end. (Socket is lying down)
This puts about a 1" lift to your trailing arm. (Frame pocket to trailing arm about 1 inch)
Above from Van Steel's suspension video.
Mapman
Old Jan 5, 2026 | 09:17 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Originally Posted by jigoe007
Guys:
In my 71 AIM the page you're looking for is 2 pages before the one you show. It's title is "Suspension Attaching Parts" and as LARS said, it's 45-55 lbs-ft.
Old Jan 6, 2026 | 01:53 PM
jigoe007's Avatar
jigoe007
Thanks for all the info!
Old Jan 11, 2026 | 10:18 PM
jigoe007's Avatar
jigoe007
I noticed today there are no shims around the trailing arms inside the frame! BTW this is a project car I picked up last summer. My car was made in Dec. '68 so it doesn't have the cotter pin holes to help retain the slotted shims. I really want to use the slotted ones but I'd have to drill holes for the cotter pin. I'll find out next weekend if I can fit the drill in there.
To Need Torque Spec: Bolt / Screw
