Bent rear spring plate?
And second-hand parts are as rare as the 1969 ZL1 option...
That said, I just want to ask the collective brain trust if the pictured spring-to-diff attaching plate of mine is TOO bent to repair/straighten (i.e. forge by vice or BFH)?
Now let's see if I can figure out how to attach my pix...
This is just to show what the other pix are about.
Thank you!
Or maybe that is how it got bent in the first place?
BFH and an anvil.
Thank you!
Cut a 1 foot 2x4 1 foot length and get a friend to hold the 2x4 on the curved end and smash down on the end of 2x4 with a ""heavy"" sledge hammer. Just don't hit your friend
He can use a pair of Tongs to get out of the way
Also tighten bolts snug and when full weight is on the ground then tighten more.
Hope this helps
Two questions then:
1) Would it help to heat the plate before beating the bejeezuz out of it, and
2) What IS the correct torque figure? This seems to be debated a lot. The AIM says +/- 70 ft-lbs, but that is apparently enough to cause problems. Thus, I recall some knowledgeable folks suggesting 35 ft-lbs. And, yeah, I've read many times about not giving full torque until the car is resting completely on its wheels.
Thanks, again.
i would go 33# torque final on ground…no more
my install here..watch bolt length
https://www.corvetteforum.com/forums...-spring-2.html
