1977- engine issue. What to do?
Old Feb 22, 2026 | 07:53 AM
corvettelover25's Avatar
corvettelover25
Default 1977- engine issue. What to do?
Hi all- I have a 1977 Corvette that’s all original and stock. After 50 years I think the engine is beginning to drop a valve or something. Idle and accelerator are fine, but when you decelerate there’s a ticking sound coming from the engine.
Three questions:
1) anyone had this happen and it not be an internal engine issue?
2) is it worth trying to rebuild the engine if that’s what it is?
3) if the engine is bad, I’m considering a new engine with a little more aggressive sound and more horsepower. I’d prefer something that drops in and bolts up without significant drive train modifications. I’m not wanting a drag car type of sound, but something that sounds more like a muscle car that isn’t insanely loud for my kids that ride in the car. Any suggestions? Anyone done this with videos and specs?
Old Feb 22, 2026 | 10:52 AM
Piersonpie's Avatar
Piersonpie
If you upload a video to YouTube you can then post it on here. There’s a lot of things it could be. Are you positive it’s from the engine and not the transmission, rear end, U-joints, or wheels?
If you go down the rebuild route I would go with the recommendations given in this thread.
As for a new engine there’s many different places that sell complete or nearly complete small blocks that bolt in and use the same accessories as what came with the car. Blueprint Engines seems to be a popular choice on here. Here’s their website.
Old Feb 22, 2026 | 11:59 AM
MelWff's Avatar
MelWff
Three questions:
Are you sure you don't have an exhaust leak where the manifolds attach to the head or where the pipes attach to the manifolds?
Old Feb 22, 2026 | 12:17 PM
OldCarBum's Avatar
OldCarBum
Another cause besides those mentioned above could be a loose worn out timing chain that’s slapping around in the timing cover.
They will tighten when the torque in the engine is applied but will slap around during deceleration.
If you find it’s time to rebuild the engine, find a good well recommended machine shop in your area and have your original engine rebuilt.
There’s several things you can do to wake up that 77 engine.
Depending on where you live and the emission laws you could deck the block and heads for a slight increase in compression ratio, swap the intake manifold, install a mild camshaft, have Lars rebuild the original carb and have a nice exhaust system put on without a lot of expense.
If the engine isn’t broken then a good rebuild with new pistons, rings, bearings, hone or bore and a valve job can be done for a reasonable cost.
Old Feb 22, 2026 | 08:00 PM
interpon's Avatar
interpon
Maybe motor or transmission mounts as well might be hitting fan.
maybe brake and watch engine under load forward and reverse.
Old Feb 23, 2026 | 10:43 AM
Bikespace's Avatar
Bikespace
Photos, and especially a video, can really help with diagnosing over the internet.
With the help of the Forum, I found the source of the clunking in my 80 in this way.
https://www.corvetteforum.com/forums...nd-videos.html
Old Feb 23, 2026 | 02:57 PM
Rebelyell's Avatar
Rebelyell
Can YOU wrangle, wrestle & rebuild a 500 pound motor ? Have proper space, tools & skills ? And universally-supportive housemates ? Have relations w/ local automotive machine shop ?
Old Feb 24, 2026 | 07:12 AM
ScottinMaine's Avatar
ScottinMaine
When checking for an exhaust leak, don't forget to check the choke tube plate on the exhaust crossover on the intake manifold. I chased that one for a couple weeks. Use a length of plastic hose with one end stuck in your ear, you'll be surprised how loud it can be when you find it.
Good advice to read Leigh1322's post. Long but thorough.
To 1977- engine issue. What to do?
