When to replace points
Old Mar 18, 2026 | 11:10 AM
kissarmy007's Avatar
kissarmy007
Default When to replace points
Hey all. 71 BB just replaced plugs, wires, rotor and cap my question is when should the points be replaced. Thank you.
Old Mar 18, 2026 | 11:19 AM
lars's Avatar
lars
The points should be replaced when you observe significant "pitting" on the contact surfaces, and/or when the rubbing block starts wearing down. Wear of the rubbing block will result in the timing retarding from it's initial setting. A good set of points will easily run 20,000 miles with no issue. A crappy set of "UniPoints" will last you out the driveway and to the end of the street, so get a good quality set of points, such as the NAPA/Echlin CS786 with the RR175 condenser.
Lars
Old Mar 18, 2026 | 03:04 PM
Alan 71's Avatar
Alan 71
Hello,
In the sixties it was quite widely known that the cover on a book of matches was just about perfect for setting the point's GAP.
Regards....
Old Mar 18, 2026 | 03:22 PM
jjcoledo3's Avatar
jjcoledo3
2 silver vets
Points should be part of the work you already did.
Old Mar 18, 2026 | 04:23 PM
kanvasman's Avatar
kanvasman
Agree that the points should be changed out when you do the cap and the rotor, since you are already in there. And not only was the book of match book cover perfect to set the gap, but the striker part was also good for filing down the pitting on the contacts. Now for the younger people, if you don't know what a book of matches was, Google it.
Old Mar 18, 2026 | 10:15 PM
Rebelyell's Avatar
Rebelyell
and the cellophane from cig pack --- manually align timing marks, put the CP in between the two contacts, loosen point set tension until CP can be gently slid out, now the ign timing is set as well; at least good enough to get ya down the road. Works on old harleys w/ points as well.
thanks be to God, I've long since thrown the cigs and matches away !
Old Mar 19, 2026 | 04:56 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Setting timing never used the plastic wrap from the cigarette pack. Always used a cigarette paper. And it still works.
Old Mar 19, 2026 | 05:09 AM
1860army's Avatar
1860army
The foil from a pack of Winstons could be used to wrap a blown fuse to get your VW home......(not recommended)
60
Old Mar 19, 2026 | 10:32 PM
kissarmy007
thank you for all your help guys
Old Mar 19, 2026 | 11:07 PM
OldCarBum's Avatar
OldCarBum
If I remember correctly, back when mostly all new cars came equipped from the factory with points ignition, the service manuals stated to tune up the engine at least every 10,000 to 12,000 miles.
Oil change was every 3,000 miles.
I always kept a set of feeler gauges in my tool kit in the trunk, which always had a fresh set of points, condenser, cap, rotor plus a dry rag just in case any moisture built up under the cap.
To When to replace points
